Question about KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator
I need a part for this fridge, Model #KBRA20EMSS.
This fridge has a wide center drawer with a lid on it. It slides out for better access to the items inside, like your cold cuts, cheese etc...
The lids plastic hindge broke and I need to find a new lid. Sears does not have any parts for this item, any suggestions where i can find it?
Thank you,
Ariana
My kenmore elite grab n' go fridge model number 795.72063.112 has frost build up behind the drawers how do I remove the drawers to get rid of the frost so my door will slide closed all the way???
There are little tabs that need to be pushed in on both sides of the top drawer with a small screw driver. Be careful as they may break! Drawer will pull all the way out to then access the next drawer.
Nov 07, 2017 | Kenmore Refrigerators
How to remove drawers
Depends on the type of drawer slide. The easy glide when pulled all the way out will have a small black finger type tab on each side. One will push down and the other lift up to release the drawer. If they are free rolling basic drawer guides there should be a lock tab in the center toward the back of the drawer that you will push up to release the drawer. However, there is usually an access pane or a dummy wall that can be remove to give you better access to the pump.
Apr 28, 2014 | Forest River 2011 Salem Sport XL 376SRVBS
How to remove center desk drawer
Some drawers have slides that have latches that have to be manually depressed simultaneously, in ordert to remove the center drawer. Look at the slides and see if there is a button, or possibly a machined strip of metal, that releases a latch that keeps the drawer from falling off the end of the slide.
Sep 17, 2017 | Hal Leonard Music
The start button fell or broke behind the panell
top lid needs to be slid back first to access console, this is achieved by removing 3 Torx Screws size T20 from rear of lid. Next: slide dispenser drawer out and press down on tab in rear of drawer and remove complete dispenser drawer out.
you can now see another Torx Screw that needs to be removed. once this is done, the console will snap out of place, just grab it buy the center and corner and tug on it carefully, you will hear clip unsnap and entire console will be accessible
Mar 26, 2013 | Washing Machines
Custom cool drawer sliding mechanism broke
Most of the rail slides, when they break apart, cannot be repaired. It would be better to replace the complete assembly.
Aug 18, 2012 | Refrigerators
I have a fisher and paykel dd24ph6 model that will not lock. Where is the locking mechanism located?
the way the dish drawer locks is the lid lowers onto the drawer..on the sides of the drawer are motors that lower and lock the lid into place ..to get to them the drawer must be removed,to remove the drawer remove th pins from the side of the drawer,slide down and off the front panel and push and and release the tabs that lock the drawer to the slide rails..then push the slides back slightly and lift off drawer..on the sides connected to support bracket on each side will be a lid motor. It is advisable to replace both at once
Aug 24, 2011 | Fisher and Paykel DS605I Built-in...
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Feb 04, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator Logo
64 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
