Question about Apple Power Mac G5 Desktop
G4 start up i get a error icon a floppy disk with a ? mark .
Help how do i recover my start up on my g4 ....... and i don't have a disk .
  • dialea Dec 14, 2007
    HELP !
  • 36 Answers
You need to get a disk. Go to apple.com, your local computer store or an apple store and buy a Mac Os X disk.
Posted on Jan 11, 2008
    Problem Solver:
  • 6 Answers
The only optiom is with disk, however if you want your data then, Please follow the below mention method.
Well if you have an same model with the similar configuration try to boot your machine from that unit in target disk mode.
Then we will be able to recover all your data.
I hope this helps you.
Posted on Dec 14, 2007
Operating system not found
Don't take this the wrong way, but start by making sure there is no floppy disk in the drive, CD ROM, or sometimes even a USB flash drive can cause booting to fail. If the boot order is such that those devices are checked before the HDD then you could see this message.
Also, if you have installed another Hard Drive recently then the BIOS can sometimes choose to boot from the wrong drive and you can get this error as well.
See this link for more information:http://h10010.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c00364979&lc=en&product=403835
Mar 14, 2012 | HP Compaq ProLiant ML110 G4 Server
My Apple g4 laptop was working a few hours ago, but then wouldn't start up with the password prompt and has a small icon with a question mark and appleface symbol. It has a DVD in it that I recently...
The disc will eject if you start with the clicker pressed (same with a mouse) the machine is OK but cannot find a viable OS boot from a Cd and in the top menu find the utilities folder, in there find disk utility and if the hd shows up select it and select repair disk, if that runs select repair permissions, then go back to utilities and find start up disc and select rour hd and restart
Dec 07, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
I have 3 1/2" floppy drive SmartDisk FDUSB-B2. If I load a 3 1/2" floppy which contains data, the drive will read the data wihout error. When that same disk is removed from the drive and re-loaded the...
Hi David,
Likely the drive is out of alignment, and head position changes each time that you insert a disk. You might try reading the disk on a different machine and try to get the data off. But, if the drive is too far out of alignment, even this won't work.
This is also a sign of 1) Drive motor turning too fast / slowly (likely), or a viral infection of your computer.
I also have the same drive that you do, and began getting a few read / write errors when making bootable disks. Problem ultimately ended up being worn out media. Resolution was to start using USB memory sticks, but harder to boot on machines that don't have BIOS support for this.
Aug 12, 2010 | Computers & Internet
My Powerbook G4 turns on light, fan, chime but no video.
Your hard drive has lost a file needed to start up the machine. The folder with the question mark means it cannot find a useable Operating system. I hope you backed up your files you needed becuase the only real way to recover the machine is to reinstall the OS from the install disk. You must format the Hard Drive from the format option on the install disk and reinstall the OS.
May 08, 2010 | Apple PowerBook G4 Mac Notebook
I am now unable to access a floppy disk that I had been able to access for years. I now get an error message that tells me the disk has no ID address mark. How do I fix this?
Try changing the stting switch on the disk. I think it is for formatting or something like that. Try moving it to the opposite direction and then put it in your computer again ;) Good Luck
Nov 12, 2009 | Teac Floppy Drive 235HF Internal Floppy...
When my imac g4 tries to bootup it shows a folder icon
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Oct 03, 2009 | Apple iMac G4 Desktop
I have a Apple PowerMac G4 with around 384MB-512MB of ram. currently when i power it up it comes up with a flashing folder with a question mark. my problem is that after i put in my OSXTiger disk...it...
My kernal panics we RAM related, if possible, make sure they are seated properly. The ? means it can't find a bootable start up drive. If you have another mac, join it by firewire and start up the new mac, holding down the letter "T" key. then see if you can start up from that disk (now in "Target mode" using System Prefferences -> Start up disk. Then run Disk Repair from Utilities -> Disk Utility. This might help. Otherwise it might be a logic board problem.
Sep 13, 2009 | Apple iMac G4 Desktop
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
Blue screen on laptop with little image of floppy disk in middle
Your laptop is unable to find an operating system. Try booting from a start up disc and running the diagnostics on your hard drive.
May 17, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple Power Mac G5 Desktop Logo
53 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
