Question about Uniden BC60XLT-1 Handheld Scanner
How do I reset the scanner frequencies all at once; what is the button combination to push
    President:
  • 2,761 Answers
There is no master reset/clear function on this scanner, but with only 10 channels it's fairly simple to enter "0.0E" on each channel to clear the programmed frequency.
Posted on Dec 01, 2009
HOW DO I LOCK THE KEYS?
Hello, there is no way to lock the keypad like one would a cell phone to prevent the accidental pushing of buttons. However if you are listening to a transmission and you want to stop it on the frequency it is at so you don't miss any of the conversation simply push "man" (manual) on your keypad and it will remain on that frequency until you hit "scan" again. Once you hit "scan" it will begin to trunk. The "lock" button on your scanner is to lock the lights on so they don't shut off in **** a short time. Hope this helps.
Regards, Tony
Mar 24, 2011 | Radio Shack Pro-97 Handheld Scanner
How do you program a bearcat bc55xlrt scanner with a code?
There are no codes, only frequencies. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
To program your BC55XLT:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
You will want to lock out constant "broadcast" services such as NOAA or airport weather. Pressing Lockout will toggle the feature on and off.
Select a channel to program. Use the keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Jan 12, 2010 | Radio Communications
How do i program my BC 55xlt uniden scanner?
To program:
Turn on radio.
Pressing Lockout will toggle the status.
To program:
Select channel. Use keypad to enter frequency. Use "E" for Enter
decimal point.
Dec 04, 2009 | Uniden Radio Communications
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
Nov 07, 2009 | Uniden BC248CLT Base Scanner
What steps do i take too program frequences. what are the frequences for charlotte north carolina?
with the scanner on, push the "man" (manual) button. If the scanner was scanning it should stop on one channel . Push the up or down arrow key until you get to the channel you want to program. You can also use the keyboard for direct access to a particular channel i.e. push "1" "4" "9" and "man" to jump to channel 149.
Once on the channel you want to program, push "prog" (program) then the frequency you want in that channel, including the decimal point. Push "ent"(enter). Your desired frequency should be displayed. Don't forget the "." (decimal point) or the scanner will tell you "error". Move to your next hannel to be programmed and repeat. If you put in a frequency outside of the radio's capability, you wil get an error message.
To find frequencies, look on the internet. The best site I have found is
http://www.radioreference.com/ .
Oct 27, 2009 | Radio Shack Pro-2054 Base Scanner
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
Frequency Range Bands:
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
New to scanners - BC898T - how to search
i cant get the scanner to search all frequencies
Feb 02, 2009 | Uniden BC898T Base Scanner
Unlocking channels
first press the manual button so you can go through the channels one by one. Then look for a button that has L/O(lock out) push this once for every channel you have a frequency programmed for it, the channel will probably not unlock if there is no frequecy programmed to it.
per roupe50 above
Dec 25, 2008 | Radio Shack Pro-95 Handheld Scanner
Scanning programmed channels
Not exactly. You can program channels however into the Private bank. To do so though you must search for the channel first...This may simply mean going to a channel you already know by using the band button to start searching...Push the hold button to stop it close to the frequency and then use the arrow keys to get to the exact frequency. then push the Prog button. After pushing it, push the Private button (you will see CH next to the frequency) using the arrow keys select the channel you want to store on and push Prog again. To scan the stored channels simply push the private button...Done! It can be a tedious process...expecially with 50 channels....but It's the only way I know how to do it...Good luck!
May 11, 2008 | Uniden BC350C Base Scanner
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Uniden BC60XLT-1 Handheld Scanner Logo
235 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
