Question about Sanyo DP42746 42 in. Plasma Television
Power light comes on, but no sound or picture
After 1 year and 9 months, when we turn the TV on (with the power button or remote), the light comes on the bottom left corner, but no picture or sound. No lightning hit the TV or anything, my wife said the TV had some strange colors on it for a minute and then went black.
Sanyo won't do anything for me, I'd like to try to fix it myself, but need to learn where to start.
  • 4 more comments
  • davidl340 Dec 14, 2007
    Thanks for your answer. I'll give it a try. I assume that the circuit that runs the IR receiver and power light must be run by a separate power supply.
    I have a buddy who is very familiar with electronics, even does surface mounting on his own. I might actually have a shot at this between you guys, myself and him.
  • davidl340 Dec 15, 2007
    There is an error indicator light flashing on the main logic board. It indicates error: D12V
    The logic board is a samsung TOP-424PA . It also has LJ44-00092F written on it. The board it self receives a 120 AC current.
    I can take pictures if anyone would think it would be helpful.
    Any ideas.
    OK, I measured the voltage to the above mentioned power supply board, and the 12 volt side measures 12 volts like it should.
    I unplugged one of the 3 main cords that went to the other circuit boards, when I unplugged one of them, the PS would then come up and stay on. Do you think I have a short somewhere on that circuit?
  • leon taylor Dec 04, 2008
    where can we find these buffer boards and main boards
    where can I get these buffer and main boards for sayno dp42746
  • looney_titus Dec 16, 2008
    i have the same prob but i found a error code d12v. do any of you no what this means
I just tryed to only replace the Y-Main board and for about 5 mins the TV stayed on but a bunch of static on screen, then died again. Must be the Main and Y-Buffer boards.
Posted on Nov 11, 2008
Kevin, I have the exact same symptoms. I replaced the Y-Main on a hunch. I was incorrect, the TV started up for 30 seconds and then shorted out the board. You will probably need the Logic board and the Y-Main. Let me know if this fixes the problem or if someone has gotten their TV repaired at a shop.
Posted on Feb 13, 2008
    Problem Solver:
  • 5 Answers
Most probable cause is a bad power supply, or at least that where to start. Lay unit flat on a blanket or carpet, being careful not to twist the display. Remove the back panel, probably 15-20 screws, and measure output voltages on the PSU. There should be silk screen ID's to help. - If any are missing or off, then replace the PSU.
Posted on Dec 14, 2007
I had the same problem and my tv was out of warranty. I took it to a local repair shop and they told me didn't work on that brand. They said they charge $300 minimum for labor, plus parts. So probably at least $500 to fix. Since I figured we had nothing to lose my buddy and I took it to our shop at work and decided to take it apart and look for any obvious problems such as blown fuses, burned components, etc. All of the printed circuit boards are connected to what appears to be similar to a motherboard via datapower light comes on, but no sound or picture - 1.gif ribbons. We disconnected the data ribbon of each PCB to the microprocessor PCB and turned on the TV. Each time it turned back off after about 3 seconds. When we disconnected the Y-Main PCB the TV stayed on and I got the sound back, but no picture. We then disconnected the buffer PCB's from the Y-Main to ensure they were not the problem. Finally, we pulled the fuse on the Y-Main PCB and reconnected the data ribbon and the TV and sound stayed on again. I found a site that sells the Y-Main for $179 and I am deciding whether to try it or not. Any suggestions or comments would be helpful.
Posted on Jan 25, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Is there any way to buy a CPU for HLR5667WAX/XAA? How to replace it?
If you TV is 9 years old it is questionable whether further repairs are economically worthwhile.
Jun 05, 2014 | Samsung Cooling Fan Set for HLR5667WAX/XAA
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
I have a problem with getting the tv started (power on). When we first got the tv 5 years ago it would not start with the global power on button on the remote. We would have to move the botton on the...
Most likely you have the problem in the power supply. In most cases you can actually see small capacitors swollen . IF you replace these with new ones your problem will likely be solved. It does require soldering.
Feb 21, 2011 | RCA L32WD12 32 in. LCD HDTV
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
No picture for 3-4 minutes after start up
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Sanyo vizon dp42746 problem
Anyone have a suggestion for this? This thing is a year old and is kaput.... anything????
Oct 01, 2007 | Televison & Video
No sound-power switch on T.V. flashing 9 times
May be a bad optoIC. Goto to see if they have a repair kit for your model.
Oct 05, 2006 | Philips Magnavox 51MP392H Rear Projection...
Sanyo DP42746 42 in. Plasma Television Logo
1,686 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
