Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
The string in the spool of the weed eater is stuck. How can I remove the string and how can I avoid this problem in the future? I'm using the pre-cut strings. Thanks
  • 279 Answers
Sounds like one of the loops is over the one being fed out. Does that make sense? I hope so. If one of the windings of string is over another, it makes it hard to unwind. Maybe if you were to put on a glove and really pull on the string, it would start to unwind. Other than that, pull the head and check the string. Good luck...Lee
Posted on Sep 20, 2009
Black & decker LST201 direction loading the string weed eater
when you are holding the spool on which you wind the string wind the string on in a anticlockwise direction
if it uses 2 strings ( one out of each side of the spool
wind in both strings together in the anticlockwise direction
that way , when you put the spool in the head and go to use it , the string is wound the right way to feed out and not get tangled
Sep 10, 2016 | Sewing Machines
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How to replace string on te475y
Hi jtl91370...
Try this solution...
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
The line on the B & D Electric Weed Eater has broken off. I can take the Orange cover off, but I do not know how to get the spool so I can continue weed eating.
Not avoiding the answer but if you google (" re-string a weed wacker video?" ), you can watch a video of how to do it, which may be a lot easier to understand when you see it.
Jun 30, 2011 | Black & Decker Vacuums
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Do not know how to correctly string so string will come out as it is supposed to on my poulan pro weedeater, do not have directions
There are five ways to change trimmer line depending upon the style of trimmer head on your unit.
The first style has a locking tab on the side of the trimmer head that must be depressed while the lock ring is turned counter-clockwise. This will remove the cover and give access to the spool which can then be pulled out, rewound with the line (winding in the direction of the arrows on the spool), and re-installed.
The second style requires lining up the marks on the bottom of the spool tap/button assembly and firmly pulling straight out on the tap button. This pulls the spool assembly out so it can be re-wound and inserted back into the hub assembly.
The third style requires pushing in and down on the two locking tabs on the side of the trimmer head. This will remove the cover and give you access to the spool.
The fourth style of trimmer head is the Centrex. Remove the cap on the bottom of the head by unscrewing it. Remove the guide ring and remove the spool from the unit. Cut a 25ft length of line and insert one end into the center cavity of the empty spool. Feed the line into the spool, leaving 4-6 inches unwound from the center of the spool. Reinstall the spool, guide and cap, making sure the notch in the guide is facing away from the spool and the line is in the notch.
The fifth style is the fixed line cutting head. This style cutting head uses a pre-cut piece of cutting line. After removing the worn line from the cutting head, insert the precut piece into the positioning tunnel leaving an equal amount out each side of the tunnel. The ends of the line can then be inserted through the exit tunnels.
Oct 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
621 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
