Question about Dell DimensionTM E520 PC Desktop
I have static in my speakers - Dell DimensionTM E520 PC Desktop
  • 2,841 Answers
Static in the speakers is normally caused by a poor connection. Take all the connections apart and spray them with an electronic cleaner you can purchase at Walmart or any electronics store. Look at the connections and if you see corrosion use a pencil eraser to clean them off.
Posted on Sep 20, 2009
Major static with bluetooth speaker
With your "new" computer, you get up to 90 days of "free" technical support, via telephone, from Dell. Telephone them.
Feb 23, 2014 | Jabra Solemate Speaker System - Wireless...
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Buzzing static sound in speaker
Static can be caused by a few things.
Does the static persist if you unplug the audio cable from your computer?
If so, the static is being caused by the amplifier built in to your speakers.
If not, the static is probably caused by interference on your sound card. Try plugging the speakers in to a portable media player. You might need to replace the sound card in your computer.
May 13, 2010 | Bose Companion 3 Series II Multimedia...
Speaker sounds very staticy
This is normally due to a bad connection, however it can also be caused by a blown speaker. replace with another speaker to see if the static is still there, if you still hear the static then the speaker is fine and the wire is broken somewhere, is the sound of static goes away then problem solved.
Apr 04, 2010 | 2003 Mitsubishi Eclipse Spyder
Static only in one speaker
When you say static that they both work but one is noisy or are you saying that the only one is making a noise and nocoherent sounds coming from either
Aug 03, 2009 | Genius SP-F350 Computer Speakers
Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Mar 14, 2009 | Insignia 2.1 Speaker System (3-Piece)
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Dell DimensionTM E520 PC Desktop Logo
65 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
