Question about La Crosse Radio Controlled Atomic Clock
Hi, How do you set the time for PST when the clock reads EST? What buttons do I need to push to change this and the time? Thank you!
  • 128 Answers
3 hours ahead of EST
Posted on Sep 20, 2009
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
  • 3
  • 4
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    How to set
    Hello
    Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    I am getting EST time. I live in MST. How do I reset the time ?
    Successful reception of the time-synchronization radio2_bing.gif signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
    Feb 02, 2010 | SkyScan 86709 Atomic Wall Clock
    I need to change time zone on atomic clock to EST
    I need help setting the time zone on the sharp atomic clock model #spc364.
    Apr 18, 2009 | Bose Wave Radio
    Set the clock
    The D3 is set automatically to West Coast (PST) Time. Only when you reset the D3 can you change the time. Hit the reset button and you'll start setting up the settings. It will bring you to the clock feature. Depending on where you are in the country you will need to hit the [+] button one click for each time zone east (i.e. East Coast (EST) is three clicks). Then you need to hit the "Summer Time" button becasue of Daylight Savings Time.
    As for the Phone Book I don't use that feature so can't help you there
    May 16, 2008 | Pioneer AVIC-D3 Car DVD Player
    Digital atomic clock radio
    Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
    Mar 31, 2008 | SkyScan 34202 Clock Radio
    La Crosse Radio Controlled Atomic Clock Logo
    258 people viewed this question
    Top La Crosse Home Experts
    John
    John
    Are you a La Crosse Home Expert? Answer questions, earn points and help others
