Question about D-Link DP-300U (DHDP300U) Print Server
Can Not Print to HP LJ 1020
Hi... I have a D-Link DP-300u as a LAN print server and HP LJ 1020 (USB) plus Epson LQ2180 (LPT1) connected to it.
At first i can print without any problem to both printers.
But next day i can not print to HP.
There isn't any error printing report from my application. so I check the printserver Interface.
It is online but still can not print even a Print Test.
I thought something went wrong with HP.
So i tried to print directly by connecting the printer to my notebook and it printed perfectly.
Now my guess is that somehow printdata doesnt reach the printer or transfer from the printserver has failed.
Anyone got a solution for this one? please help. thanx
  • 2 more comments
  • Anonymous May 09, 2008
    I have got also this problem, I can install the LJ 1020, but it won't print or print test. This work on LJ 1200 and DJ 1280.
  • akhilrahi May 28, 2008
    exact same issue... prints fine on parallel port but on usb for LJ 1020 it just does not print...any help would be appreciated a lot thanks..!
  • Anonymous Jul 02, 2008
    Chack Lpt Cable
  • rajkumard2 Mar 16, 2009
    cant get the print server 300u to work with the 1020 the usb led also does not lightup
Users need Rev B hardware to use LJ 102x printers
Posted on Jul 04, 2008
    Problem Solver:
  • 8 Answers
Hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Posted on Jan 04, 2008
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
USB printer HP 1020 Plus in DP-301U
Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
Communication between PrintServer DP-301U and HP LaserJet 1020
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Alex
www.CAS411.com
Feb 13, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Configuring a Mac Book Pro laptop with a DP 300U Print Server
    I connected my HP5MP to the DP-300U LPT1 port.
    I configured my port on the DLink Configuration tab, giving it a name "hp5"
    ...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
    On my Mac, I go to System Preferences > Print & Fax
    Click the + to add a new printer
    Select the IP option
    Choose the Protocol: Line Printer Daemon - LPD
    Type in the Address: 192.168.0.10
    Type in the Queue: hp5
    Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
    and find the driver for your HP LaserJet 5MP.
    Save it. Works like magic. ;-)
    If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
    Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
    DP-300U revB and KONICA MINOLTA bizhub 163
    I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
    Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
    D-Link Print Server Compatibility issues
    DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
    Jan 27, 2008 | Sharp AR-5320 Black and White Copier
    Not printing to network attached printer
    I have a DLink DPR-1260, and found the configuration to be challenging too. First of all, has it ever worked? If not, you may need to check your router config to ensure that they are both on the same subnet. Typically they come set to 192.168.x.x... if the router is set to 192.168.1.1, the print server is set to 192.168.0.10, and your subnet mask is set to 255.255.255.0... it'll never connect. Make sure that the router and print server are configured to the same subnet... 192.168.1.x for example... and then try it. Let us know if that doesn't resolve your issue, and we'll keep working with you.
    Oct 26, 2007 | D-Link DP-300U (DHDP300U) Print Server
    D-Link DP-300U (DHDP300U) Print Server Logo
    1,201 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
