Question about Kenwood VR-507 Receiver
No sound from my VR-507
My Kenwood VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. Sometimes I will turn it on and the sound is back, then other times there's nothing. I tried running the speaker setup to see if it would output pink noise, but I couldn't hear that either.
Please help. :-(
  • porscheflt91 Dec 25, 2008
    Mine is only sending soundvery faintly through the center speaker only. This is only after you turn the system all the way up to the max. I crpss check all the inputs with different devices from the Play Station to a Ipod to all the inputs. I alsoswitched the RCA as well. It was perfect yesterday but today i have nothing. I have had the system in use for years on a daily bases. Also you can hear the same signal through all the input setting as you change it from Video 1,2,3, and Aux.
My KenwoodNo sound from my VR-507 - 1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Posted on Feb 07, 2008
2 Suggested Answers
SOURCE: Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Posted on Mar 21, 2009
My vr-507 shut down to protect my speakers but will not power up now.
Sounds like the output transistors in the amp are blown. Try powering on without speakers attached - if it still shuts off your amp is blown and needs to be repaired.
Jan 17, 2014 | Kenwood VR-507 Receiver
Need too hook up surround sound kenwood vr507
In other words you need the manual.
Register and download the manual for free at retrevo.com
Jun 14, 2011 | Kenwood VR-507 Receiver
Cannot get the receiver to connect to a newer
It would be the rare TV that originated anything approaching the sound quality of any other audio source in your home or could process digital multichannel audio anywhere near as well as the Kenwood. What model TV did you say this was? Its internal audio controls could also be part of the problem.
TV-related audio is best derived from as close to its source as possible. Your cable, satellite DVD, BD all have superior digital multichannel audio outputs. Why would you want to filter them through the TV first?
Those sources may also have HDMI which would be great for the TV; they also have standard RCA stereo outputs, each of which could be suitable to run to the TV's RCA inputs if you only want to watch news or weather with lo-fi sound.
Bottom line recommendation: BEST video to the TV; best audio to the Kenwood.
Mar 20, 2010 | Kenwood VR-507 Receiver
Kenwood VR-507 Now only get sound from 1 front speaker. all other speakers have stopped. Have not changed anything.
PROCESS OF ELIMINATION: connect each of the other speaker in the working to check to see if the wires and other speakers are working. If all speaker play when connected to the working channel check all other cables and connections....use the tuner as an working source to test. If that doesn't help then you may have an bad channel in your amp and may need to be repaired.
Oct 31, 2009 | Kenwood VR-507 Receiver
I need the connection wires!
This uses regular speaker wire. Go to Best Buy, Radio Shack, or any electronics store and ask for speaker wire.
Oct 04, 2009 | Kenwood VR-507 Receiver
Kenwood VR-209 turns off after 20 minutes
Overheating is likely your root cause. Move the unit to make sure it is getting enough air around it and remove anything that you have sitting on top of it ESPECIALLY any device that produces heat of it's own such as your CD player. If that does not solve the problem, listen at a lower volume and/or defeat any equalization or bass enhancement circuitry.
May 09, 2009 | Kenwood VR-209 Receiver
Remote will not program
See this website. It worked for me and I've never soldered before.
http://mysite.verizon.net/amp68/
Sep 02, 2008 | Kenwood VR-507 Receiver
Sep 22, 2007 | Kenwood VR-507 Receiver
Kenwood VR-507 Receiver Logo
674 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
