Battery will not charge compaq presario v5000
have already bought a new battery
sometimes it shows charging symbol but battery does not charge
sometimes just shows ac is being accessed (battery not charging)
when using old battery that was dead, would run on ac power and then just turn off all of a sudden (usually within 1 to 5 minutes). since using new battery that came 58% charged (now only 55% charged), the notebook has not turned off when using.
  • Bill Schilz
    Bill Schilz May 11, 2010
    Have you tried running it without a battery in it at all? If it will not run that way, you have a bad AC adaptor/charger OR a bad connection in the back of your laptop.
    Guru:
  • 830 Answers
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Posted on Sep 20, 2009
Testimonial: "good advice"
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
Battery won't charge
there is a problem of your notebook not of battery yu need to contact compaq customer care they will resolve your queries quickly.
Oct 07, 2009 | Compaq Presario 1711T Notebook
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Laptop isn't working
have the charger tested, the original battery may have been flat, because of charger failure rather than battery failure. try an automotive connector if one is available
2c worth
Jul 11, 2008 | HP Compaq Presario V5000Z Notebook
V5000 problems
what you need 2 do is either take the whole laptop back 2 where you brought it or even the battery cause you have a faulty battery.
most laptop batterys last for at least 5-10 years and after that no matter how much you charge them up they alwayz seem to be flat.
so my suggestion is get a new battery or take it back to the place that you brought it from and than get it replaced for free as long as you have your recept.
Jul 06, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Computers & Internet Logo
685 people viewed this question
Alun Cox
David Payne
David Payne
