Question about Dean SR14E Deep Fryer
Dean Gas Fryer need new thermostat? Please help!
I purchased an older, used Dean gas floor fryer. The Model number is SR38GM, the thermostat I removed is stamped ...TC125-004 400F 9822. The pilot light will stay lit but the burners go on and off. Even when the thermostat is set to "off" it will ignite.I've done a search for the numbers, but nothing comes up. Please help. Thank you!
SOURCE: Dean SM35GM pilot light low and burners won't ignite
Check out this link for a Dean manual
http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/manuals.html
Posted on Aug 19, 2009
bigg t
  • 640 Answers
SOURCE: dean fryer
You need a new valve,Goto northernparts.com search for the make and model.Make sure you get a propane valve.
Posted on Sep 04, 2008
  • 19 Answers
SOURCE: dean french fryer need new burnners
http://www.a1service.com/dean/deanburner.htm
Posted on Feb 05, 2009
  • 19 Answers
SOURCE: gas igniter kit
It could be converted by a qualifed kitchen mechanic. Here is a list of parts for your unit, and supplier.
  • 833 Answers
SOURCE: Dean gas deep fryer burner on high will not respond to temp set
The thermostat is likely welded shut. You'll have to change it out.
Posted on Feb 25, 2009
I have a fm45esd natural gas fryer and i have flames comming out the front of the unit. any clues
The gas valve may be leaking gas out where it should not be leaking gas out. You may need a new gas valve. This could be a safety issue, not just with a fire, but a potential fire gas explosion. Please get it fixed ASAP.
Dec 18, 2013 | Frymaster Dean FM345EETC Deep Fryer
My deep fryer pilot somtimes goes out after burners ignite
I assume this is a natural gas fryer....Are your jets clean? That is an issue sometimes, and those are the small holes that your flames come out of....Is your gas line clogged anywhere....? I don't sell Dean fryers, not too impressed by that brand, as they leak quite often, and then Dean won't honor their warranty program....so I'm not as familiar with their products, however on some brands, the thermostat dial itself should not be turned to the holding temperature until after it lights and is fully on...Do you turn it to say 350 degrees right away or wait for it to light before selecting your temperature? Thermostats themselves going bad is the number one issue with fryers, so it could be that. To clean out the burner jets, we use a compressor and blow them out clean...You can also use a small brush or skewer to clean them out. I would eliminate everything you can that has no costs involved first, and then move to parts that you have to purchase. If you need a thermostat, I could get you a price on Monday... Our toll free number is 888-542-5959, Restaurant Equipment Outlet, Cincinnati, Ohio. We would need the brand/model number and serial if you have it also. Our service tech who specializes in gas products is off Monday, but there are other people there who can help and get you pricing on parts. I won't be in until after lunch myself Monday, but check out what you can, and if nothing works, then call us on Mon or Tues next week.
Everything is closed up until Monday, so we can't order or get pricing over the week-end. Good luck, hope this helps.
Susan
REO
Nov 22, 2011 | Frymaster Dean SR42G Deep Fryer
Pilot light stays lit when I turn the gas valve to on. But nothing happens when I Turn the thermostat on. Help
The thermostat control is bad, you will need to replace the thermostat switch and everything will work just fine. Basically the thermostat switch is not sending a signal to the gas valve telling to to turn on
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
We have a dean deep fryer model SR42GNS on start it makes a big boom and a large blue flame comes out of stack on top?
is the fryer propane or natrual gas?It sounds like the orfices,burners or baffles may be clogged and needs cleaning.let me know.
Apr 08, 2009 | Frymaster Dean 2424G Deep Fryer
Feb 25, 2009 | Dean SR14E Deep Fryer
Gas igniter kit
Sep 03, 2008 | Dean SM20G2 Deep Fryer
Dean fryer
Sep 02, 2008 | Dean SR14E Deep Fryer
Frymaster gf 14 won't come on
Ok sounds like your problem maybe that the gas valve is set to low. If you have access to a manometer you can put it on the outflow port of the gas valve and see what the reading is. It should be at 4" water column for this fryer. You possibly might even have a faulty gas valve, these will go out sometimes and still let the pilot bypass maintain regular operation. Please comment me back if you need more assistance with this.
Thanks
Jul 14, 2008 | Frymaster Dean FM345EETC Deep Fryer
Dean SR14E Deep Fryer Logo
381 people viewed this question
Top Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Paul Carew
Are you a Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
