Question about Gestetner Office Equipment & Supplies
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
  • yibeltal f Oct 01, 2009
    Thank u for ur help, but still the problem is as its. Even i didn?t get the DIP switch of "gestetner 2722ztd copier", i don?t know the real location can u locate again
    In addition i try to reset using the following steps to revove the error("E 1") msg
    1. Press yellow clear button
    2. Press 107
    3. Press orange clear/stop button for 5 sec
    After this step the screen goes from error "E 1" to blinking "1" I try to switch off and switch on again the main switch but the problem is display error "E 1"again
    Please help me if u have time
  • Gestetner Master
  • 1,297 Answers
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Posted on Sep 20, 2009
Move the expo lamp to the home position and you will clear it out.e1 problem
Posted on Apr 09, 2012
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
Feb 26, 2013 | Gestetner Office Equipment & Supplies
What causes error 12 on a gestetner 6123 duplicator
6123 gestetner digital copy printer no salve problum single line on copy. cleane complete scanner and thermalhead,
May 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
Gestetner 2722 ztd error code E-5 when press "."see 47 what can I do ?
i have gestener 2722ztd that displayes E-5 when i turn on it.
what i can do with the machine
Sep 30, 2011 | Gestetner Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
I have gestener 2722ztd copier & it dispay E1 error
refers to optics, blown lamp most likeley
or scanner home psn
Nov 05, 2010 | Office Equipment & Supplies
How can I solve error code E-1 on my gestetner 2722ztd photocopier? the error occurs when I turned on the power
u need to get a full error code press star or hash key to get the rest
my gues its 101 which is exposure lamp brocken or something to do with optics
Nov 02, 2010 | Gestetner Office Equipment & Supplies
My printer is one 2722ztd and has this erros E-5 what is it? thank you for your help
Most E5 code of this unit came from defective fuser unit. press ( . ) so see the third number so we could pin point the defective part or section.
Jul 08, 2010 | Gestetner Office Equipment & Supplies
Haw to reset gestetner2722ztd error E1
press dot ( . ) on the left side of 0 so we could know whats the second defree number is. to reset press energy saver once then 107 press stop button until 1 blinks then 5 # 810 # turn off copier then on.
Jan 10, 2010 | Gestetner Copier
265 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
