Question about Samsung Washing Machines
SAMSUNG J1253 WASHING MACHINE -The error code 6E appears mid cycle ,can you advise what the problem is?
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
SOURCE: i have a j1453 washing
6E error means ambient temperature is too low.
A problem that occurs when the potentiometer connected in series with the thermistor on the microprocessor board is damaged.
for more details try this link:-
http://applianceguru.com/view_topic.php?id=3721&forum_id=2&jump_to=95478
As this is under generic problems on all washing machines, the link will surely help.
Posted on Dec 13, 2008
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
SOURCE: SAMSUNG 845 - ERROR MESSAGE HE2 - not in manual
heater or wiring
Posted on Aug 19, 2010
HI, MY SAMSUNG WASHING MACHINE WF-B1061 RECENTLY GOT ERROR IT SAYS 6E WHAT DOES IT MEAN? AND ALSO WHEN I SWITCH ON THE WATER GOES IN PROPERLY BUT SUDDENLY IT TURNS TO ERROR. THANKS & REGARDS WILL
6e error mean heater not functioning. Check the heater element and if is bad change it. If the heater element is ok, check the connection to electronic board.
All the best !
Apr 21, 2018 | Samsung Washing Machines
I have Samsung J845 front loader washing machine. The error code bE or 6E is showing up. It won't spin at all and barely drains
Possibly a short circuit to motor or PCB
Requires a competent repair engineer to fix.
Check mains supply
Check main control module
Check main drive motor
Mar 22, 2016 | Samsung Washing Machines
My Samsung washing machine p1453 stops after 10 mins washing and comes up with code error 6E which is not in the manual
They usually stop with an unbalance load or If its a newer model and u use h.e detergent or suppose to be using it, and if u use it or another detergent to much , to heavy many newer washer have a suds sensor and when it detects to much detergent it will shut u down
Oct 03, 2014 | Washing Machines
Samsung p1453 error code 6e?
6e fault is saying that the temperature is not high enough, this is most likely a malfunctioning temperature sensor or an issue inside the electronics.
Mar 10, 2012 | Computers & Internet
SAMSUNG J1253 ERROR CODE 4E
Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
May 03, 2017 | Samsung Washing Machines
I have error 6E on my samsung washer
If during the spin cycle, the error code could be an error with the printed circuit board assembly of the washer. This means that the temperature readings are incorrect and the error will continue to display.
E6 error code indicates that the water heater is heating water too fast. Press the power button once to clear the error and finish the cycle before repair.
Check this link with additional info: original/457.jpg?1285349415
Hope this helps.
Apr 18, 2011 | Washing Machines
What is erro code 6e on a samsung washing machine
Don"t worry too much about the error code, press pause, and then press pause again, the cycle should continue. If the counter does not countdown, ideally,as long as your washing is in the machine for 30-35 mins that should be ample time, then press pause and put your dial on the final cycle from rinse to spin, if this does not work, try picking a longer wash cycle, leave for 30-35 mins, then press pause and fast-track to your final stage of rinse to spin, Good Luck!
Apr 16, 2011 | Washing Machines
I have a j1453 washing machine and im getting an error code 6e.what does this mean?
Dec 13, 2008 | Samsung Washing Machines
Stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
Mar 11, 2008 | Samsung WF337AA Front Load Washer
Open Questions:
Washing Machines Logo
307 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
