Question about Motorola Mobility RAZR V3
Pairing a Jabra 250 headset with my new motorazr2
Can you help me pair my jabra headset with my phone please?
    Scholar:
  • 181 Answers
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Posted on Dec 18, 2007
I have a Jabra Clear that won't match up with my phone
The first thing I'd suggest you do is to turn your cell phone off and, if possible, remove its battery for 10 to 15 seconds. Then replace the battery and turn the phone back on. If taking the battery off the phone is not possible, simply delete everything on the Bluetooth pairing memory. Also, we will need to reset the Jabra headset to the factory settings.
Turn the headset ON. Then press and hold the volume down and answer/end buttons at the same time for approx. 5 seconds until the battery icon and Bluetooth® icon flash 5 times simultaneously - then the pairing list is reset.
Turn the headset OFF. The next time you power on, the headset will go into pairing mode as the first time you powered your new Jabra headset on.
Once in pairing mode, your cell phone should be able to add the Jabra headset as a new device from within its Bluetooth menu.
Nov 11, 2014 | Jabra Products - BT2080 Monaural...
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
Connecting cell phone and Jabra
Check that both devices are BT enabled and in pairing mode -ie, leds blinking-. If one of the device is not in pairing mode, it is normal that the process fails.
If you experience the same problem on other phones with your Jabra BCE-250 -same as mine-, you might think of getting it checked first.
Dec 10, 2009 | Jabra BT250 Consumer Headset
Google g1 phone jabra bt125
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
Apr 15, 2009 | Jabra BT125 Headset
How to set the Jaba BT500 headset in pairing mode?
Jabra has an online tutorial on pairing.
It can be found here:
http://jabra.pairx.co.uk/
Choose your BT500V from the list, then choose your phone / pda model from the next menus.
Jun 20, 2008 | Jabra BT500V Wireless Headset
Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Mar 24, 2008 | Jabra BT250 Consumer Headset
Problem pairing
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Jan 27, 2008 | Jabra BT130 Wireless Headset
Pairing problem
Dec 23, 2007 | Radio Communications
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Mar 20, 2007 | Jabra BT250 Consumer Headset
Motorola Mobility RAZR V3 Logo
186 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
