Question about GE JKP45 Electric Double Oven
The bottom oven works fine. The control panel for the top oven is functioning but the oven will not heat up (It shuts down after about 45 seconds). Model JKP45WOT1WW. 10 years old.
SOURCE: Bottom Oven Does not work - F64 Code on Panel
i have the same problem and im in oakhurst. the repair person thought it was because the bottom oven does not close fully which i should have had fixed under warranty. they are coming oout on friday
Posted on Aug 16, 2007
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
JKP55 The top oven would not heat. Got it fixed for $261.00 with tax. The bake element in the upper oven was bad. My oven unit is 14 years old.
Posted on Feb 07, 2009
heatman101
  • 43501 Answers
SOURCE: Oven Was Self Cleaning. Bottom Oven Opens Top Oven Does NOt
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jul 30, 2010
KevinWhite
  • 1902 Answers
SOURCE: !0 year old GE Profile
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
The top oven works fine. All functions on bottom oven are OK but will not heat
Break the problem up. Start at the elements. Do they get power? If not work your way back to the output of the control. Is there power there? If not replace the control. Otherwise check all wiring
Jan 14, 2015 | Frigidaire 27 in. Electric Gallery Pro...
The bottom element blew out on my Maytag electric range. I replaced it but still does not heat. I checked and there is no power coming to the element. All other functions, broil and top burners work fine....
without knowing the model I'm going to give you the most probable issue.
The wires that connect to the element plug in have become brittle and bad there's no more connection.. they need to be repaired.
I'm sure you know this but....shut off power to the unit while working on it.
best to you.
Jan 24, 2018 | Maytag 30" Built-In Single Electric Wall...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
Nov 14, 2007 | GE JKP45 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
GE JKP45 Electric Double Oven Logo
78 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
