Question about NetGear WGT624 Wireless Router
Wifi as Laptop to PC Hub?
I was told I could use my wifi router as a hub to allow my laptop to see my pc but this isn't working. My pc is hooked up to my sbc router and wifi, and is working perfectly. My laptop has wifi and again works perfectly. I was told I could log onto my pc using the \192.168.0.2 (as in my case). I get the error that it cannot be found. Thanks for any help!
  • 1 more comment
  • jclovesus Dec 17, 2007
    Thank you for taking the time to ask these questions. I will do my best to answer them.
    Yes both my PC and laptop work with the internet. When I configured my setup I didn't enter any IP address, at least I do not remember. I believe all of this was done for me. The 192.168.0.2 is for my PC, 0.1 is my wifi, and 0.3 is my laptop.
    Are your PC and Laptop a windows computers? YES ALL WINXP.
    Which version Windows XP? SORRY I WILL HAVE TO CHECK.
    If Windows XP
    Do you know if you are using windows firewall? NOT USING WIN BUT MCAFEE.
    If so did you set the firewall to allow file and printer sharing? NOT AWARE OF THIS...IS THIS WHAT WILL ALLOW MY LAPTOP TO SEE MY PC? WILL INVESTIGATE.
    Do you run an internet security program or firewall program on your computer? MCAFEE
    What is it's name
    Do you know if it has a firewall? YES
    IF you know it has a firewall
    was it enabled to allow File and Printer Sharing? NOT AWARE OF THIS BUT WILL INVESTIGATE.
    When sharing files like this security of the wireless connection becomes more critical. Do you want to discuss securing your wireless connection? I DO HAVE IT ENCRYPTED, IS THIS THE SAME THING?
    I hope that helps. THANK YOU FOR YOUR HELP!
  • sjk64 Dec 21, 2007
    trying to load Netgear wizzard for 108mbps WGT624 wireless router> Even though I am on the internet, wizzard states that it cannot detect the internet. I have McAffee Security on my computer & have disabled the firewall, still no go...any suggestions? Sean
  • jclovesus Dec 23, 2007
    Thank you for your help! I went ahead and set up File Sharing as suggested, and then had to add in my PC's IP address into McAfee on my Laptop, and all worked then. My only other question is with File Sharing turned on does this compromise any security at all? Either way now my Laptop and my PC can talk through my Wifi. Thank you very much.
  • 556 Answers
This is not a solution and is not deserving of a rating (yet anyway) -- please wait to rate this until a solution is provided.
A few questions before attempting an answer please confirm or explain if your network and computer systems do or do not match the following (please indicate that you do not know to any items where it is appropriate and I will try to provide instructions to determine the answer) You are the eyes and hands of this team and all I know about your systems is what you report here. A successful resolution of this issue will require both of us.
If both your PC and your laptop work with the internet indicate they do in your response and skip down to the question about the static IP assignment to your PC of the 192.168.0.2 address and continue from there.
First in terms of wiring starting at a phone jack
Does the phone jack (where you would plug in a phone) connect to the SBC Modem (possibly through a splitter)?
Does the SBC Modem connect with an ethernet cable to the
Router?
via the WAN port or
one of the (probably) 4 LAN ports?
Is your PC connected to one of the Lan ports or is it wireless? from your message it appears to be wireless.
Your laptop appears to be connected wirelessly does it work
with the internet?
When you configured the IP address of your desktop PC did you enter a static IP Address for the either the wireless adapter or the wired connection of 192.168.0.2? Please indicate which adapter you configured with this address if you did so.
(please answer separately all of the below for each computer
your PC and your laptop)
If Windows XP
What is it's name
I know this was a lot of questions but there can be numerous reasons for the problem you described and these answers will eliminate some issues and highlight others for review.
Posted on Dec 14, 2007
  • 2 more comments
  • david Dec 17, 2007
    Boy do you have the answers --
    Yes encryption is the mechanism that implements wireless security you appear to be covered.
    In terms of file sharing and firewalls - (protecting ports) -- if the PC will share it files with the laptop but the laptop is not going to have a folder of files to share with the PC only the PC needs file sharing enabled and the appropriate ports open. Warning I believe XP has a shared folder (I believe supporting anonymous read access by default) once file sharing is enabled for the machine -- you may wish to investigate that too.
    Turning on file printer and sharing (part of the network configuration that may be done - the reason it may not work is probably the firewall setting) has some risks such as the preconfigured shared files folder above. Shares you create and files in them could be accessible which is why I like the share password protected but I have not figured how to do that with windows XP yet for each specific user I want to have access.
    Once you have the target shared folder and firewall configured correctly. Based on the addressing you stated creating a new network connection on the laptop pointed at the pc would appear as follows
    (PC computername) should be replaced with the PC's Computer Name) and
    (share name on PC) should be replace with the share name you assigned on the PC
    (please ignore link it's the editor)
    \\192.168.0.1\(share
    name on pc) sometimes
    \\(PC computername)\(share name on PC)
    with the appropriate userid and password, if required (I believe it should be just in case). Is the step that allows the laptop to access the PC's files
    I will respond again if I can determine how to secure a shared folder in Windows XP which may be limited to certain versions. I I will also include how to make one then too.
    Found it.
    The link indicates that Windows XP defaults to simple sharing -- which is the only options for Windows XP Home and further explains how to turn on the world I know in Windows XP Professional.
    You will not need to understand this but if you do it will not hurt.
    http://support.microsoft.com/kb/307874
    Right mouse click on My Computer (may be in the menu) and select properties. I need you to tell me what is says on the general tab after System: it will identify your version of windows.
  • david Dec 24, 2007
    Yes XP defaults to simple file sharing you share with anyone that can access your computer. At a minimum I would put WEP encryption on the router and the network adapter for the wireless computer to prevent sharing with your neighbors or people with laptop on the street. If you are in an apartment -- even worse.
    sjk64 -- are you on the internet using the router you are attempting to configure?? Is this a second router attached by its WAN port to the one you are trying to do the configuration from. I believe routers expect to be configured from their lan side ports including possibly wireless in some cases. Most routers are setup to reject remote configuration from the factory which I would consider to be the WAN side of the router where you may be attached at the present time.
Looking to set up wifi cant find wifi name on the network
Make sure the WiFi hub is on and transmitting before looking for it. Try another laptop to test the hub.
Nov 01, 2013 | Computers & Internet
I have a 8ta internet stick and there is allot of wifi data on it, how can I use that data and setup wifi on my laptop?
I dont think you must use this stick for this purpose. Except if you know where to find the wifi code of your hub or router. This code is what you enter in your wireless-connections (usually on the router somewhere) and your laptop will have internet. With a wire-connection you can insert or even change the wifi-code.
Oct 28, 2013 | Computers & Internet
I need a pass through wifi router
The best soultion is to install a hub or a network switch.
If your wireless router has LAN ports then connect your computer with a LAN cable to the wireless router.
Feb 07, 2013 | Computers & Internet
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
Im trying to connect my wii to the internet at my new house and it won't it keeps saying unable to find access point. please confirm the ssid and try again?
I'll advise briefly, but suggest you find the router page address (something like 198.168.2.1). You can find this by looking in the manual for the router. You can also double click to open the router and then "open device webpage"
This will allow you to access the router settings and configure the wireless protocols and passwords / security. Without knowing which router you are using, I cannot give specific help.
You need to ensure that the wireless password that you set in the router is typed EXACTLY into the network connection on your PC / laptop
Jun 13, 2011 | Nintendo Wii Console
How do I connect my laptop to the internet in a building without wifi
Without using an wifi or wireless is you are going to the UTP Wires "LAN WIRES" provided that this wires is connected with HUB or Router. That's the basic procedure on how to connect without wifi.
Oct 04, 2009 | Computers & Internet
Cannot connect to wifi on our bt home hub
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Dec 10, 2008 | Computers & Internet
Cannot connect to wifi from bt home hub any suggestions. laptop higrade 8615gtx
Now:
type cmd and enter
How to add one more laptop in the network
just connect your laptop to a rj 45 jack connected to the switch, or hub. if you have a wireless router you can connect to it via wifi.
Mar 13, 2008 | Computers & Internet
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
NetGear WGT624 Wireless Router Logo
83 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
