Question about Polar T31 Transmitter and Belt Set
Polar FT60 heart Rate monitor worked fine for about 8 months. I attempted to use one day & found that I get the following message "Check Heart Rate Transmitter". I have seen this before when the transmitter strap was not making good contact. I adjusted the strap but still the same error. I have replaced both the watch battery & the transmitter battery. The watch seems to work properly, but it is difficult to tell if the transmitter is working. I measured a small voltage from the snaps on the back side of the transmitter when activated and have purchased a new transmitter strap. Any ideas?
  • Tim Key Sep 21, 2009
    I tried a brand new transmitter strap and it too behaved in the same way as the first transmitter strap. Is there a sync process that has to be completed after a battery change? Syncing the transmitter to the watch?
    President:
  • 1,653 Answers
This generally means that either the battery needs repalcing or as you say when the transmitter strap is not making good contact. You should clean the strap with some surgical spirit on a clean cloth, preferably lint free cotton, and tthen wipe down with a saline solution made from 1 tablespoon table salt dissolved in 1 pint of water, again using a lint free cloth.
Posted on Sep 20, 2009
  • Karl Wright
    Karl Wright Sep 21, 2009
    No they should sync automatically.
    I would remove the transmitter battery and check the contacts for oil / grease etc and then reinsert it. Assuming the watch is working OK then you do not have to do this again.
    Have you checked the voltage of the transmitter battery itself? It should be a nominal 3V and if it is new you should see a slightly higher figure. If you have an ammeter then the nominal capacity of the CR2025 battery is 150mAH. Wipe it down with a clean soft dry lint free cloth or rub it with a piece of clean kitchen roll paper to make sure that both faces of the battery are clean. As the battery is the same for the watch and transmitter you can place the transmitter battery in the watch to see if it is OK. The transmitter battery should last for between 1.5 and 2 years after a new battery is installed and the watch battery should last between 1 and 1.5 years.
    WARNING. You should also download all the data in your watch to make sure that it is completely empty of stored data before removing its battery. Make sure that you remove the watch battery carefully if you do so as not to damage the case seal. If in doubt don’t attempt it!
    If you get nowhere your unit should be under a 2 year warranty so you can return it to Polar for servicing or replacement free of charge.
  • Karl Wright
    If you get nowhere your unit should be under a 2 year warranty so you can return it to Polar for servicing free of charge.
    President:
  • 2,004 Answers
When left idle for so long a time out of use, the gadget kind of get expired.
Would not be sure if that is the case but you might have to replace it.
Cheers.
Posted on Sep 21, 2009
  • Onifade Adewunmi
    Onifade Adewunmi Sep 21, 2009
    On a better note, I will advice you take it to the shop you bought the Monitor from or better still contact the manufacturer.
    Rate my suggestion, please.
Heart rate will not read via transmitter
well it happend to me some month ago. the thing is there is no easy solution. when you stop using you monitor for a long period,the sweat does something to the strap and it stop working. so the way i resolved was nicely cleaning the belt and then dip it in water. After that i wet my chest and i would repeat the process as many times as necessary to make it work.
But the problem go away completely only after my 9th o 10th session on the treadmill
May 16, 2013 | Polar Exercise & Fitness
HOW DO I SET TIME AND DATE ON MY POLAR AXN500?
For all those who lost their Polar Heart Rate Monitor manuals. Follow this link, fill in the details and get manual. Plenty of other Polar product info and support on this site.http://www.polar.fi/en/support/downloads?product=&category=User+manuals
Aug 26, 2012 | Polar AXN500 Heart Rate Monitor Watch HRM...
Polar ft40 watch doesnt work. I have replaced the battery and nothing happens.
This heart rate monitor has a generic flaw with the sensor. The touch sensor fails after a few months of use. It is not a battery issue. Return to where you purchased it. Buy another brand. All of the drug stores carry this watch which has an abnormal return rate. The sensor fails after a few months while the watch function is fine. Seems like planned obsolescence.
Sep 07, 2011 | Polar Electro Polar FT40F heart rate...
Which Polar heart rate monitors work with Fuel Fitness FS320e Elliptical
Any analog signal Polar should work fine. Stay away from the RS-800 series.
Mar 26, 2011 | Polar Heart Rate Monitors
The battery was flat. renewed it and all working EXCEPT it no longer can pick up heart rate from monitor (tried it with another monitor and still will not pick up heart beat) Help Please...about...
i guess stopped of use your strap for a long period of time. so you need to nicely clean the strap and try a lot of times until it work again.
I happend to me before and the strap worked only after the 10th session on the treadmill
Feb 11, 2011 | Polar FT60 Heart Rate Monitor (Purple)...
Heart rate reading low
try this link for the manual.
polar f11 heart rate monitor manual Google Search .
However, you may wish to reset the unit and start over with new settings. You can resetyour Polar F11 by following a few easy steps. Press any button to activate the Polar F11 Fitness heart monitor unit. Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button.
How to Reset a Polar F11 ' Healthfully
https://healthfully.com/reset-polar-f11-7176556.html reset polar f11 heart rate monitor Google Search
Oct 29, 2017 | Polar F11 Heart Rate Monitor
Polar T31 Transmitter and Belt Set Logo
1,199 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
