Question about IBM ThinkPad T20 2647 Notebook
"Critical Battery Error" even with not battery in laptop
My stepdad's ThinkPad T20 is giving a "Critical Battery Error" and then shutting right back down, when start up. It even does this when the battery is removed and the laptop is plugged in. Any idea's what could be causing this?
  • 2 more comments
  • Tmobley Dec 18, 2007
    No, I don't. The Power supply for my laptop which is an Acer Aspire has a smaller end on it. It will not work. I cannot tell if it is keeping the correct date and time, because it will not load at all. When I push the power button to start it up, the first thing that comes up is a black screen that says "critical battery error" It then instantly shuts back down again.
  • Tmobley Dec 20, 2007
    Thank you, I hadn't even thought of the cmos battery. It might take me a little while to get one, busy with the holidays and all. I'll post back and let you know if that fixes it.
  • waynes Dec 25, 2007
    "critical battery error" when pw up A31 with no battery, lights come
    on and computer powers down.
    With full bat computer powers on with or without battery but no
    charging of bat. computer WinXP runs good but shows only bay
    symbol.
    fuses on Sysboard ok, 16volts on sysboard but no 3.0v and 2.0v
    to battery.
    I think problem is on sysboard and hope to fix
    thanks
  • golfclaudio Jul 01, 2008
    the battery of the pc is unloaded and the message appears 0190. connect it to the net 220 volts it doesn't happen anything and it doesn't reload the battery! I have changed feeder thinking that was broken but have not resolved the problem! ideas? thanks!
Hi
were do you find cmos battery to replace it mines having the same problem and i just replaced the main battery
Posted on Dec 18, 2007
    Scholar:
  • 181 Answers
Do you have another power supply to use?
Also, is it keeping correct time and date?
Posted on Dec 14, 2007
  • jim walenciak
    jim walenciak Dec 18, 2007
    I'm pretty sure the "190" "critical battery error" is not the main battery, but the cmos battery.
    T20 cmos batteries are not prone to be weak, however, they are getting along in years, so replacing it is certainly a very inexpensive investment for a pretty fair laptop.
    If you have trouble with IBMs service manual for the T20, just post back and I'll give directions.
    Good luck
0190: critical low battery error
When old IBM Think Pads fail to boot it is usually because the CMOS battery has worn out. It is very easy and inexpensive to replace. Youtube has numerous videos showing how to replace it e.g. https://www.youtube.com/watch?v=8ZI-8Q2j-zQ
Jan 24, 2018 | IBM ThinkPad A30 Notebook
How do I remove the backup battery from my Thinkpad 2647 T23? I'm trying to remove the POP.
ThinkPad T23 2647
Manufacturer - IBM
Series - T Series
Subseries - ThinkPad T23
Machine Type - 2647
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Battery removed, Battery Compartment facing you.
Look at the right inside edge. There is a small plastic cover inside the Battery Compartment.
Remove the one Philips head screw, then remove the cover.
Backup battery, CMOS battery, or RTC battery. SAME/same.
(Real Time Clock battery)
Also, here is the Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
Drop down to the 8th line. (ThinkPad T20. T20 in blue)
Scroll over, and left-click right on - T23
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name, (T23), it may take up to 30 seconds, before the first page comes up.
Start on Page 66. Backup Battery is on Page 67.
OR,
In the Bookmarks menu to the left, click on -
1) The + sign to the left of -
ThinkPad T20, T21, T22, and T23 series.
2) The + sign to the left of -
Removing and replacing an FRU.
(Field Replaceable Unit)
3) Left-click right on - 1010 Battery Pack, and 1020 Backup Battery.
Nice to have when you are going to clean that puppy out.
(BUY, and wear an ESD wrist strap. Connect it's alligator clip to a good ground source.
Average price is around $3 to $6)
Also nice to have to upgrade the Processor, and a myriad of other things.
Regards,
joecoolvette
May 11, 2012 | IBM ThinkPad T23 2647 Notebook
0190 critical low battery error
push the power button at the same time with thinkpad button, and fast press F1 key.
you should need to do this 3 times to fix the problem.
May 14, 2011 | IBM ThinkPad T20 2647 Notebook
Ibm think pad r32 0196 critical low-battery error will boot up then turns it self of
Fail safe in the battery has engaged. See if the computer will start without the battery, using just the power supply. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery. Also change the CMOS battery inside the computer
Change the CMOS battery
Nov 04, 2009 | IBM ThinkPad T20 2647 Notebook
Laptop doesnt turn on when I press on the on/off button
Remove the battery for 10 minutes, put it back in, plug to power supply for an hour or two then try again.
Please don't forget to rate this
Mar 20, 2009 | IBM ThinkPad T20 2647 Notebook
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
Ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Nov 05, 2008 | IBM ThinkPad T20 2647 Notebook
Critical low battery error 190
This sounds like a fail safe in the battery has engaged. See if the machine will start without the battery, on the supply only. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery.
Aug 28, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
1,781 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
