Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Stops after a few minutes
I can only use the vacuum for about 5 minutes then it stops and I have to wait about 45 minutes for it to run again. I've followed the manual directions and checked for blockages.
  • kylebm_2000 Sep 24, 2009
    It sucked up the tissue just fine and I don't see any obstruction.
  • Chemist1961 May 11, 2010
    Try sucking a tissue through the hose, if it makes it into the dirt canister, the hose is clear. Also check the throta of the vac about 3 inches inside to see if you have an obstruction. then post back
    Sergeant:
  • 197 Answers
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Posted on Sep 20, 2009
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Why does my DC17 Animal vacuum keep shutting off?
Hi Emmeline,
I'm sorry to hear you're having difficulties with your DC17. From what you've described, it sounds as if the thermal cutout feature is shutting the machine down to prevent overheating. If you've already tried washing the filter and are still experiencing the issue, I'd encourage you stop using the cleaner and to contact us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vax infinity 1900 suddenly stopped working now no power gets to it, i've changed fuse still no power.
I have an infinity nv29 that stopped working while I was vacuuming. According to the manual I was supposed to unplug it for about 45 minutes and then try it again. I waited for over an hour and tried it again and it still won't turn on. Any suggestions?
Feb 06, 2010 | Euro-Pro NV31 Infinity Vacuum
After a few minutes the hoover stops. After waiting a few minutes it runs again but the problem keeps repeating
You haven't stated the exact make and model but in general what you're experiencing is a safety feature: your machine is overheating and cuts out to prevent a fire.
Check that the bag isn't full and also check the moving parts for anything which is preventing proper operation. I can't give you specifics as you haven't even said whether it's a cylinder or an upright cleaner.
DO NOT continue to use your vacuum cleaner until you know what the problem is. In it's present state it's a fire risk.
Oct 05, 2009 | Electrolux Vacuums
Protection light
it might be the bag or the sensor inside the machine.
Jun 28, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Keeps stopping.
your battery isn't holding a charge ,buy a new battery
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
447 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
