Question about Amana Washing Machines
LWR50AW 9904000131 is leaking from the bottom of the center of the machine. How do we take it apart to solve this problem? Thank you, Norma Marchant
    Brigadier General:
  • 8,619 Answers
Hi
You'll need to replace the transmission seal. For this repair job you’ll require special tools like T20 Screwdriver and other similar tools. You can disassemble the machine by following the steps mentioned below--
1. Remove the front panel (screws on each side)
2 Remove the two 3/8 screws pointing upward. This will allow you to lift the top up.
3. Remove the agitator.
4. Remove the spanner nut (requires tool and its left hand thread).
5. Remove the top off the outer tub (some snap off and some have a clamp all the way around the tub)
6. Remove inter tub.
7. Remove the set screws in the mounting stem (the treaded stem that the spanner nut was on).
8. Now with the same tool remove the mounting stem.
9. The outer tub is mounted to three legs. Remove the bolts that hold it on and remove the hoses from the tub. Once it is done remove the outer tub.
10. Remove the rubber boot.
11. Prop the tub up on something so that you won’t damage the stem that the drain hose connects to and step on the seal to push it out.
12. Turn the tub back over and install the new one the same way (may want to lube it with a small amount of soap).
13. On the transmission there is a metal sleeve where the tub sits, remove it. Now reinstall the new sleeve.
14. Reassemble the washer replacing the seal, boot, tub bearing, mounting stem and spanner nut.
This may help you--
Also check the Drain pump and drain hoses inside the washer if they are firmly connected and not leaking. You can see this diagram for more details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 20, 2009
Water intake won't shut off, door popped open, water all over the place.
Thank you for your post, Norma!
I see that the water valve would not shut off inside of your Frigidaire washer and caused the door to open then leak on your floor. This could be an issue with your water valve, control panel, or door latch. The door should not open when in operation. I would recommend contacting your manufacturer for further assistance for your washer. -Matt
Jan 02, 2016 | Frigidaire Washing Machines
Why is water leaking from bottom of double stack fridgidaire washer/dryer combo?
Thank you for your post, friend!
From the information you have provided your Frigidaire laundry center is leaking water from the bottom after a day or so. It sounds like you have a slow leak and this could be in your drain line, drain pump, or gasket. I would advise you to review your gasket and drain hose to make sure there is no visible crack or wear that water could be leaking out of. If you do not see any apparent leaks it could be an issue internally and this is not a simply DIY job. You may need to request the assistance of a professional technician for proper disassembly of your laundry center. I hope this information has been helpful. -Matt
Feb 18, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
Replace Water Pump on Roper Model 8280871
Thanks for posting the solution which helps to solve if anyone has the same problem.
Thanks
Mar 31, 2012 | Washing Machines
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Leaking water
thank u for bringing your probl to our notice.
well, for leaking from the washing machine is mostly a directly result of wear n tear of drain gate rubber washer, try replacing the washer with new one, will solve your problem, or else u can give it to nearest serive center, u'll b delt within an hour.
not a major problem to worry sir.
if my solution has helped u, then plz give a vote as a feedback. thank u.
Jul 15, 2009 | GE Washing Machines
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My washing machine keeps leaking from the bottom
There are many possible cause of a leak. If it is set to portable make sure that the faucet is off after the cycle. You also need to make sure that you are not over loading the washing machine. Please refer to owners manual how much is the capacity your washing machine can take. Drain lines is also a possibility for this leak as well as the intake inlet. If it's leaking in the center most likely the bearing have broke off and you might need a new center seal. This job requires a professional to be replaced. My advice for Avanti users is to return it and buy something else that is trusted and branded for quality and performance.
Apr 26, 2007 | Avanti W851 Top Load Washer
Washing Machines Logo
218 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
