Question about Toshiba 32A43 32" TV
Buttons on front unresponsive
All buttons on my TV are unresponsive - power can only be turned off by unplugging, volume goes to max and channels go from highest to lowest or vice-versa automatically.
Is this TV done for?
  • 232 Answers
Front control board needs to be replaced or eprom is corrupted one or the other, would have to do a couple of checks to know for sure, a tv tech can tell you 20 minutes after he gets there, neither part is a big bucks repair, hope this helps, BMW Rider
Posted on Dec 14, 2007
When you turn the tv on, the volume bar shows 20 and goes to 0 and none of the buttons will work
As a owner of a olevia who's company went out of my problem was TV will not turn on - think it may be a broken AC power panel. ... I cannot turn the power on or off, and NONE of the buttons work, nor ... For a while now when you accidentally unplug it from the wall or the power goes out it ... LED will flash continuously along with the volume going up to max. ..... It's a 37 inch. send it to a pro for repair
May 16, 2014 | Olevia LT37HV 37 in. HD-Ready LCD...
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
The volume to the tv goes to max when you turn it on?
that hapened because your remonte contral has the + button pressed just release the volum + at your remonte and all will be ok
or try to hide your remonte control and get down sound from front panel of your tv
Dec 11, 2008 | Televison & Video
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Volume goes up on its own!
Hi, We are Zener
we suggest you reset the tv with a secuence of service
that is exclusive with the remote,
is pressing the buttons(display channel 5 volume + power)
the tv turn on, appears parameters on the screen, only press
8 and enter, all your set get as you buy it.
Note: change any parameter, because you are getting in the tlevision`s memory.
Zener, from Mexico
Jul 22, 2008 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Volume stuck maxed out
the intrenal switch that controls the volume up is shorted. you need to have it replaced. the short of the switch doesn't allow any other buttons on the set to work because the micro is recieving the volume up command. it's as if there is an invisible finger pushing the volume up button. the switch is a tachtile switch which is very inexpencive to repair about $50.00 total. if you want to do the repair yourself be aware there are voltages that remain in the set that can be harmful. 50% of the time the cause of these switches shorting is improper screen cleaning. some people spray glass cleaner directly on the screen, this is bad. the cleaner drips into the set and lands on the PC board where the buttons are housed. but I've seen the other 50% also which is hummidity, dust(not anyones fault this just happens), and simple switch failure. so becareful repairing it your self
Feb 10, 2008 | Toshiba 36A40 36" TV
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Toshiba 32A43 32" TV Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
