Question about Maytag MDE308DAYW Electric Dryer
Maytag dryer mde308dayw, grinding noise, the rollers at the back of the dryer still have an inch of rubber on them, the sound appears to be coming from the bottom of the dryer, near the pulley, your thoughts?
    President:
  • 512 Answers
A few things to check. Have you pulled drum, something could be caught between drum and body of dryer in the felt seal area. Or bearings in rollers could be worn. Also check belt tensioner way be worn. Thats all there is to a dryer has to be one of these.
Posted on Sep 20, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This may happen due to a worn out belt or a broken gear in the transmission. And can also be due to idler pulley issue. Please disassemble it by following this procedure--
Drum Removal / Roller / Glide Access
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal—
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip
between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. 4. Depress the locking tabs on switch side and remove
through the front.
5. Remove two screws, 1 each side, from the back flange
of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel
to the back side and remove gasket.
  • Remove wires from light, see “Light Removal”
  • Remove four screws on Front Bulkhead.
  • Remove belt from Idler Pulley.
  • Grasp the Drum with one hand and the belt with the other. Lift the Drum and slide out the front. Carefully spread the cabinet as needed to gain additional clearance.
  • Rear Rollers and Glides can be serviced as needed.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
I have a maytag dryer that will not start. When I push the start knob, I get a buzzing noise that sounds like there is something wrong electrically behind the control panel. I took off the panel in the...
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Hi, what you describe indeed sounds very bad, and should be looked into asap, to do this yourself you will need a service and repair manual, accordingly i have provided a link above for you to obtain one.
You will need to be very careful, as with any electrical fault, the service manual has troubleshooting steps for you to follow so you can isolate and repair your problem.
Buzzing noises usually have to do with the motor, or gears belt etc.
Also to help below is a DIY website that will help you also
.http://www.acmehowto.com/howto/appliance/dryergoe.php
Feb 01, 2011 | Maytag MDE308DAYW Electric Dryer
Dryer tumbles very loudly?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer squeals then quites then squeals
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 25, 2010 | Maytag MDE308DAYW Electric Dryer
My Maytag model MDE308DAYW squeaks and grinds when turned on.
i would assume that either the rear roller(located directly atop your heater, or yout idler pulley has gone bad , parts are probly about $40.. not a bad repair, you can probly find a how to on you tube
Oct 09, 2010 | Maytag MDE308DAYW Electric Dryer
I own a Maytag Quiet Series 100 Electric Dryer (MDET446AYW). There is a loud high pitched sound as the drum is spinning. Sometimes the sound diminishes or temporarily goes away as the dryer "heats" up...
heatman101
Sep 16, 2010 | Maytag Dryers
Grinding noise in Maytag dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS Your problem sounds like drum rollers have flat spots on them or in need of lubrication.If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Mar 03, 2010 | Dryers
Grinding noise in drum at rear
if your slides went bad, theres a good chance your drum was out of alignment it probably gotr worn on the back side and is now gringing when in the right position......
the good part here is the tumbler carries a ten year warrenty
Sep 26, 2009 | Maytag MDE308DAYW Electric Dryer
Grinding noise
In my humble opinion, a dryer making a grinding noise is worth repairing. Possible Problems:
Worn Drum Rollers (Very Likely): More of a thumping / grinding sound. Replacing drum roller supports is considered to be a routine "normal ware & tear" repair with parts costing about $15 - $20 or so. Its' kinda like a tune-up for a vehicle. The rollers can be located in a couple places, but are typically located on the inside rear of the drum; upon dis-assembling the dryer.
Broken/Loose Blower Fan Wheel (Likely): The blower wheel can become loose or brake off the motor shaft and can make a "rumbling / grinding sound and can run about $15 - $25 for the part. The degree is difficulty when repairing a little high, but is commonly performed.
* Note: Removing and threading the blower wheel is reverse to prevent the fan blower from natually spinning/coming-off "Righty loosey, lefty tighty"
- C
Jan 27, 2009 | Maytag Dryers
Dryer makes a very loud noise when turning - sounds like something is grinding. Happens on both directions of the spin. Could this be faulty or worn bearings? It is a condenser dryer, 4 yrs old
The drum support roller for your dryer (s) is worn out. In Rozzi's case is sounds like the rubber has come completely off and the drum is turning on the bare metal part of the wheel. In guest's case is sounds like one of the rollers has a chunk missing from the rubber that normally surrounds the metal wheel.
Unplug the dryer. Pull the top off the dryer. Typically a couple of screws in the back and then slide the whole top towards the front of the dryer. Lifting from the front edge open it up like a chest. Remove the drum and the belt. You should see two drum support rollers. Replace them both (and the belt while you are in there).
Sep 23, 2008 | Dryers
Maytag MDE308DAYW Electric Dryer Logo
482 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
