Question about Refrigerators
Water in door too slow coming out
I have a Whirlpool refrigerator with ice and water in the door. The water is too slow coming out. I've changed the filter and it does no good. What could be the problem?
  • 4,070 Answers
A strainer before the inlet valve can get stopped up restricting flow. It's on the back where the water supply connects.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Sep 20, 2009
catriver
  • 878 Answers
SOURCE: slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Posted on Mar 21, 2007
SOURCE: water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Posted on Oct 25, 2008
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
  • 10865 Answers
SOURCE: My Whirlpool refrigerator Model # ED5RHEXNL00 Ice maker broken
Hello. Thanks for choosing fixya! The most common cause for your problem is that someone accidentally raised the wire in the icemaker area that turns it off. Check that first if the wire is up, push it down and within a few hours you will have new ice. The second most common problem is that the cubes in the mold got stuck in there. the fix is to use a blow dryer to free them up, then dry out the mold and spray some PAM cooking spray in to the mold to lubricate it. The final possibliity is that there is ice in the water supply line that feeds your ice maker. Once again get out the blow dryer and thaw that ice so that the water flows once again. good luck with it. regards, joe
Posted on Nov 05, 2009
SOURCE: my whirlpool refrigerator ice maker does not make
I have a whirpool side by side ref with ice and water in the door. I'm getting water but no ice, I can't find my modle#.
Posted on Jan 04, 2010
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
We have plenty of water and pressure coming to the refrigerator from the house, but when we try the in-door water dispenser, the water comes out at a slow trickle. Ice is not making. We installed a new...
whirlpool has had frozen waterline issues whats temp in refrigerator and freezer make sure refrigerator no colder that 37 degrees and freezer th 6 degrees
Jan 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Jun 17, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Slow making ice. It is taking forever to fill the ice bin. What can I adjust to make it produce ice faster?
Clean the coils under the ice box so that the flow of air cools the condenser mo propah my amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 14, 2009 | LG LSC26905TT Side by Side Refrigerator
Change water filter on Whirlpool side by side Refrigerator
Jill, download the instructions here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202205958.pdf.
Jun 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in refrigerator door coming out slow
Hi Ben22 Sounds like some thing pluging the water line or the water line pinched some where.. if the hole was 1/4 inch you should get enough water with that big of a hole. I would check the water line for a obstruction. Let me know if this helps. Krazytech
Sep 29, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
881 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
