Question about Texas Instruments TI-83 Plus Calculator
How to use negative exponents on a calculator?
How do you enter a negative exponent in to your calculator? I am trying to solve 15ml * 1 * 10(-3)
and I can get my calculator to work.
Uh yes it will allow you to enter a negative exponent.... press the numbers you want then hit EXP button, then hit the +/- button and then the exponent. 60 % of the time, it works...... everytime.
Posted on Oct 13, 2012
PMT= 22775.99*(.0575/12) / 1-(1+.0575/12)^ -72
Posted on Mar 24, 2010
    Problem Solver:
  • 6 Answers
Your calculator will never allow you to enter a negative exponent. so heres what you do.Any negative exponent of a number can be reversed and turned into a fraction for example 4^-1=1/4 or 8^-2=2/8=0.25. Hope this helps.
Posted on Sep 21, 2009
How do i get a negative exponent?
I don't have this calculator, but let's give this a shot and see if it gives us the correct answer.
Let's try 10 to the exponent -2. The rule for negative exponents is to put 1 on the top and the term with a positive exponent on the bottom. In this case, it would be 1 on the top and 10 to the exponent 2 on the bottom, or 1 / 100 or 0.01.
In the calculator, enter 10, hit the x to the power of y key, left bracket (, the negative key (-), 2, the right bracket ), and finally the = key. You might not have to enter the left and right brackets, but I like to enter them to understand what I enter in brackets is the exponent.
Let me know if it works and if you have any other questions.
Good luck.
Paul
Sep 13, 2015 | Canon F-502 Calculator
How do i enter an exponent for ti-30xiis
Exponents of 10 are entered by pressing [2nd][X^-1] (EE).
For powers of any base, enter the base, press the [^] (below PI) then enter exponent. Use the (-) white key if exponent is negative.
Apr 30, 2014 | Texas Instruments TI-30 XIIS Calculator
How to solve an equation with negative exponent
You probably want to calculate the numerical value of some mathematical expression with numbers raised to negative exponents.
Just enter the expression as you would with positive exponents Except that before entering the value of an exponent press the change sign key, marked (-), or +/- or (+/-). Do not confuse the change sign with the usual minus sign, which is usually displayed bigger then the change sign. Make sure that the (-) is displayed before the value of the exponent. Use parentheses if necessary.
Feb 14, 2014 | Texas Instruments TI-30X Calculator
How to use it for exponents?
To enter exponents (1, 2, 3, -3..) use the general power key marked with Y^x or X^y or ^. Enter the base press the general power key then the exponent. If exponent is negative try enclosing it in parentheses. use the change sign key (-) to enter the negative sign before the exponent.
To enter power of 10, you can use the shortcut key marked Exp (the 10 must not appear when the Exp is used to enter exponents for power of 10).
Feb 24, 2013 | Sharp Office Equipment & Supplies
I am using a TI-30 calculator and I am trying to calculate student loan payments. I need to know how to put a negative exponent into the calculator to process the formula. Example: (1+ .0075) to an...
Depending on your version of the TI-30, you will either find a button with a y to the exponent of x or a button that is the carot (^) sign. you would type (1.0075)^(-240), where ^ is the appropriate button (y^x or just ^).
Jul 18, 2011 | Computers & Internet
How do I use a negative exponent when working working with natural exponential functions, on this calculator?
The same way you'd work with positive exponents. The only difference is that a negative exponent has a negative sign, entered with the (-) key just to the right of the decimal point.
The (-) is used to enter negative numbers, not just exponents. The - key is used to subract one value from another.
Sep 23, 2010 | Texas Instruments TI-30XA Calculator
How do i input a negative exponent on my ti30x IIs
Use the EE (enter exponent) key (2nd-shift of the key just above the 7) to enter the exponent. Use the (-) key just to the right of the decimal point to enter a negative number.
The - key subtracts one number from another. The (-) key enters a negative number.
Jun 29, 2010 | Texas Instruments TI-30 XIIS Calculator
Negative exponents? .825/(10^(-3)) ? Not sure how to get it to do the negative exponent.
You entered it correctly. Although you can leave out the parentheses if you want. The calculator will do exponents before it does multiplication or division just like it does multiplication and division before it does addition and subtraction. It has a built in order for hierarchy of operations. You only need to use parentheses if you want to do something that is different from this order. FYI, dividing by a negative exponent is the same as multiplying by a positive exponent. You could enter it in either way. .825/10^-3 = .825*10^3 = 825. I hope this helps you out.
Dec 02, 2009 | Texas Instruments TI-30XA Calculator
To the power of a negative
Use the small (-) sign sometimes labelled [(-)] or [+/-] and put the whole exponent netween parentheses 18 [y to the x] [(] [(-)] 3 [)] . On some calculators you enter the small - signe after the value of exponent,
18 [y t x] 3 (-) [Enter] should give you 1.7146E-4
In summary the small minus sign; the whole negative exponent between parentheses.
Hope it helps.
Sep 18, 2009 | Sharp EL-531VB Calculator
1.19x10-4=?
You can download the guidebook for this calculator from TI here.
From page 16:
To enter a number in scientific notation:
1) Enter up to 10 digits for the base (mantissa). If negative, press the +/- key. (The key has two curvy arrows between the + and - but I can't do that on my keyboard.)
2) Press the EE key.
3) Enter a 1 or 2-digit exponent. If negative, press +/- either before or after entering exponent.
They give the example 1.2345 +/- EE +/- 65 which would display -1.2345 -65.
Apr 07, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-83 Plus Calculator Logo
6,168 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
