Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
How to stop pen drive from opening directly, when inserted in usb port
  • 2,567 Answers
Here is a link to a page explaining how to do this:
http://blog.ashfame.com/2008/03/disable-usb-autorun-save-pc-usb-viruses/
And here is a link to a page explaining how to achieve the same result but in a different way:
http://wiki.answers.com/Q/How_to_disable_autorun_in_pen_drive
Posted on Sep 20, 2009
Testimonial: "thanks a lot "
Spy pen not working
If you have a Spy Pen, sometimes it just appears to be either stuck with the light on, or dead and won't turn on. We wrote this report to show you some of the tricks we found to getting your it to work again.
1. Perform A Hard Reset
The majority of the time, just inserting the end of a paper clip in the opening below the status light on the back, and performing a hard reset, will get your Spy Pen working. Just bend a small paper clip end out, and insert straight into the opening. When you meet resistance, push lightly, and you can feel the reset button depressed.
Make sure it goes straight in, and not at an angle, or you could damage some of the components inside. Let go and try to turn it on.
2. Rule Out The USB Cable
If you are using a USB cable to either connect the Spy Pen to your computer, or to the 110V wall charger adapter, one day the cable will fail. If you use the USB cable because you can't connect the pen directly to the computer, try just plugging it directly into the computer.
Don't use a USB hub, as sometimes there is not enough power for the it; just connect it directly to the computers USB port. On some computers, use the USB port on the back, as front USB ports are sometimes weaker.
3. Rule Out The 110V Wall Charger
Just like the USB cable, the 110V wall charger adapter will also fail at some point; so if it does not seem to take a charge, try charging it for 3 hours in the computers USB port. If the status light is on while its charging, its getting electricity to charge the battery.
4. Put The Spy Pen Back In Video Mode
Several Spy Pens have switches to go to photo mode, or voice activation mode. If you move the switch to change modes, and you do not move it back to video mode, the computer will say it is not recognized. Try moving the switch back to the original position.
5. Erase & Reformat The Spy Pen
If the Spy Pen shows up as a removable drive on your PC, just right click on the icon and let go on "Format." Then check the "Quick Format" button, then hit OK. The drive will be erased, and reformatted. This usually takes care of any pens that make it this far.
Feb 13, 2014 | Computers & Internet
How to Stop pen drive opening directly inserted usb port in windows 8
Hello
At some point, you enabled "Auto Play" on your computer and that is why the PC opens the USB drive when you connect it.
To change this, go to CONTROL PANEL and then double click AUTOPLAY.
You can set what you want to happen when each type of media is inserted into your computer on this window.
In your case, look at the REMOVABLE MEDIA area and change it from "Open a folder to view files" to "Take no Action".
Nov 03, 2013 | Computers & Internet
Hello
You can change what your computer does when media is connected to it in the Control Panel
Go to CONTROL PANEL - AUTO PLAY. From this window, you can change what the computer does when new media is inserted into your PC.
If you do not want the PC to do anything, find the media type and change the action to "Take on Action".
This will prevent the PC from opening up the media when it is connected.
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
Pen Drive not recognised
u try a different usb port ? sorry if thats not much help i try : D
Apr 30, 2010 | Electronics - Others
Malfunction
This can occur if the pen drive was inserted into a HUB rather than direct into a proper usb 2.0 port on the compuer.
It can also happen if the dmive has been mistreated in any way.
You may want to try re-format it from the computer mangement console
rather than my computer or windows explorer
Aug 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to install drivers of pen drive
your pen drive is not recognize by the usb port onyour computer, remove the pen drive from the port and insert it to another usb port on your computer, if you still having problems, restart the computer and try again on a different port.
USB drives do not drivers for it to work.
Jul 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
Pendrive detected but stil cant open
Try to insert it in every usb on your pc maybe its your usb port the problem!
Mar 22, 2009 | Computers & Internet
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
DRIVE INSTALLATION
Abhi, u don't have mention that wether can intalled directly on your system port or not? OK. First check your USB driver. If it OK then check to connect your pen drive directly on system port. If it is working well then there must be problem in your hub port or your hub might be of low speed. I think u can understand this. U only can change your hub in this case.
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
1,199 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
