Question about Sony BDP-S300 Blu-Ray Disc Player
Sony blueray not playing blueray
When i put a blu ray **** in to the player it says loding then it gives me a cannot read disk but if i put a normal dvd in it will read it
  • 82 Answers
I think in these modles there are 2 lasers one for normal dvd's and 1 for blueray my stepbrothe plays blu-ray on ps3 all the time and his packed up but normal dvd worked so try checking that or using a disk cleaner (a special disk) and try cleaning the blu-ray disk
good luck
Posted on Sep 20, 2009
Put my p-1500 in our RV. Tested with a blueray disk and worked just fine. Wanted to show wife, but it would not play any blueray. but will play standard hi-def. Any ideas?disks. Any ideas
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain lasser bean NOT reading the TOC disk +Syscon can be defective, you must go to the repair shop TV for fix it
Jul 16, 2012 | Samsung BD-P1500 Blu-Ray Player
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
My panasonic dmpbd10a blueray player wont play blueray Avatar movie
With people downloading movies illegally, companies have put blocks on DVD's, unfortunately making the DVD unplayable for some blue-ray players
http://www.njnnetwork.com/2010/04/avatar-blu-ray-wont-play-on-all-players/
May 13, 2010 | Panasonic DMP-BD10 Blu-Ray Disc Player
Sonybdp-s301 won't play 2012
Sony BDP-S301 has an upgrade to Version 5.3 to support the new Blu-ray discs. Download the software here (Click the link). Read the procedure carefully and follow it exactly.
Note: The update makes use of a burned, finalized CD DISK, not a DVD Disk.
Apr 15, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Magnavox NB500MG9 BluRay Player
A Blu-ray player can play DVD or CD and still not play Blu-ray. It may play Blu-ray but not CD or DVD, or burned discs. This is all caused by the 'optical' a part that reads the disc in the machine. Your player will need service as a Blu-ray optic cannot just be 'dropped' into a player.
Mar 28, 2010 | Magnavox NB500MG9 BluRay Player
We have a sony bdp 300 DVD. We updated the firmware several months ago and all the movies worked fine. However, now it will play just fine during the previews but when we play the movie, there is no audio....
Hi
This certainly looks like a potential firmware issue especially if the Audio is there on the previews. There are reports also of recent firmware updates causing problems on some other Sony BDP units.
You might want to try a Blueray cleaning disk which you can purchase from any good Audio store first to ensure there is not a problem with dirt on the lens that may be causing this. Simply insert and play like a normal disk and it provides a cleansing action to the lens.
Otherwise my advice is to contact Sony directly to discuss the matter and find out if there have been any recent firmware issues.
The most recent update for your unit is firmware version 4.9 and this was released on 12th June 2009
The support phone number for Sony Blueray Players is 239-768-7547
Hope this helps. Please do rate this answer. Many Thanks.
Sep 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Can I play "A" (US) bluerays on my blueray player?
Is your Blu-Ray player rated to play "A" (US) disks? If you live in another country & purchased it at a store there, chances are low. Call tech support for your Blu-ray player & see what they have to say.
Aug 28, 2009 | Televison & Video
Can Bluray be played on this DVD machine?
You can only play blue ray format on a blueray reader. Your recorder/player requires the proper laser and programing to decode large quantities of data. Your manufacturer should clearly state whether it plays blueray fomat.
May 12, 2009 | Aspire Digital AD-8091 DVD Recorder
Blu ray disc
BlueRay is a new high capacity disk storage media system. It has a much greater capacity than any of the other systems.
The blue laser light is of a much narrower beam width and higher speed computing technology, it is possible to now have a much greater capacity for data speed handling and data capacity.
All the new High Definition movies are coming out on BlueRay disks. To play these disks, a BlueRay player will be necessary.
The technology is moving at a faster rate all the time. In about five years, there is a newer system coming out that will even be ahead of the BlueRay. They are working on a new generation high speed plug-in memory modules at the consumer level. These modules will have their own full function microcontroler built in. The data will be using internal fiber optical pathways instead of metal conductive pathways. These will be much farther ahead than anything we have now.
Jerry G.
Jerry G.
Jul 23, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sony BDP-S300 Blu-Ray Disc Player Logo
511 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
