Question about Unique Interieur 1969 Chevrolet Camaro Z28 Ht Orange 1/24 Diecast Car
My alternator charges the engine when it is running but it dont chage the battery? can any one help.. this is on a 1969 gmc c1500
If your alternator is is ok then your battery may be duff
Posted on Sep 20, 2009
2011 gmc acadia alternator failed. I changed the alternator and now it will not start. Has clicking noise from under the hood. The check engine flickers rapid says service bat charge system
Charge the battery or jump start it. When the alternator dies, the car runs off the battery and drains it. Older batteries can recoup fast enough.
Aug 31, 2015 | GMC Cars & Trucks
Alternator is new.battery is new. GMC Yukon is not charging. What could the problem be.
Not sure but I believe the GMC Yukon has an in line fuse in the charging line. If so the output of the alternator will not get to the battery. One way to check is to measure the voltage, when the engine is running. At above idle it should be over 13 volts. Then measure the battery voltage, it should be almost the same within 200 to 400 mVolts. If not the charging line is open. Also if the alternator charging terminal is the same as the battery (12 to 12.7V) while the engine is running, that again indicates the alternator internal regulator is bad. If you turn on the headlights with the engine running above idle and the alternator output drops over a volt or so, the alternator is bad. This measurement can be taken at the battery plus terminal or the alternator charging output.
Feb 10, 2015 | GMC Cars & Trucks
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
Charging System for 2000 GMC 1500 Sierra 4x4
measure battery voltage while engine running good is 13V to 14V then over charging is 17V to 18V DC
if ok battery gauge could be defect
if not ok then look for stuck pulley on alternator belt by removing the belt and turn all pulley free.
hope it help
Feb 23, 2014 | 2000 GMC New Sierra 1500
My 2005 Artic Cat ATV battery wont stay charged when lights are on
maybe your alternator dont chage good.check this whit a voltmeter,on your batterie when motor is running.you chould read , some 14.50 volts.when read 12 or 13 is to low
when read 14.80 or 14.90 volts is too high
Jul 07, 2013 | Cars & Trucks
Battery will take a charge from a charger, but will not charge from driving. Alternator is ok
the alternator charges the battery thru the heavy lead on the back of the alternator that goes to the battery. make sure it is clean and tight. the alternator output should be 13-15 volts with engine running.
Apr 16, 2013 | 2002 Lincoln Continental
Alternator wont charge
at alternator gig wire battery voltage,one wire battery volts one less . battery volts wire goes to automatic shut down relay, less then battery voltage wire to pcm fuse will be 20 amp just ck all that size.
Aug 05, 2012 | 2001 GMC Sierra 2500HD
Batterywill take chage and start engine, runs if
you should have both your battery and alternator checked. many parts stores can do this for free while everything is still in vehicle. the battery may have a bad cell and only gives you enough to start once. the alternator may not be producing enough power to charge the battery and run your lights(the flickering). if you cant drive to the parts store some can still test alternator out of vehicle. call and ask
Aug 15, 2009 | 1997 Dodge Dakota
How do you install an alternator 95 gmc sierra 1500
1] disconnect the positive battery cable. 2] remove the serpentine belt.  you need a socket wrench to remove the tension from the idler arm pulley. 3]disconnect the battery wire from the alternator, and unclip the other smaller wire from the other side of the alternator. 4] remove the bolts that hold the alternator to the engine. 5]install the new one in the reverse order hope this helps
Jun 04, 2009 | 1995 GMC Sierra C1500
Unique Interieur 1969 Chevrolet Camaro Z28 Ht Orange 1/24 Diecast Car Logo
67 people viewed this question
Top Unique Interieur Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Unique Interieur Toy Expert? Answer questions, earn points and help others
