Question about Protron PD-DVR100 DVD Recorder
Setup menu cannot access the setup menu for the proton dvd recorder
  • 4 more comments
  • Anonymous Dec 22, 2007
    setting up a new recorder and selected the progressive scan mode and now I cannot get back into the setup menu to correct it or go back to factory settings. Had the menu until I selected progressive scan.
  • Brienne Dec 26, 2007
    I, too, cannot not access the setup menu since I selected the progressive mode. Is there a master reset button?
  • Anonymous Dec 28, 2007
    SAME PROBLEM
  • kimmnray Sep 10, 2008
    Same problem when I power up & hold the enter button it just flashes load forever won't power down or any thing I have to unplug from wall.
  • Anonymous Dec 16, 2008
    just says initial on the screen. Can't get it to do anything, won't even open to accept a disk. HELP!
  • tedstates Jan 12, 2009
    Hi this is re "Guest" comment on dec 22nd about the progressive scan and now not being able to access the setup menu because the screen is just black (right?) and there is only sound. I had the same problem with a dvd recorder in the UK (Which I believe is just the identical unit, only under another name (Protron in this case) The solution is to look in the user manual, and there is a "Flowchart" so to speak, which shows paths to different functions. When you find the path, you will have to try and make the changes as though you are doing it in the dark, since nothing will appear on the screen, but when you nail it, you picture WILL suddenly appear. I know this because it happened to me, BUT I've just done it again! So much for learning from your mistakes! When i get mine sorted out, I will re post the actual details.
Ok I've just found out how to get the interlaced/progressive problem sorted out. It is as follows and PLEASE REMEMBER you will be doing this "Blind" sice the screen is black:
1. Power on the DVD unit.
2..Press the "SET UP" button on the remote, ONCE (DVD Display should show "Setup" )
3. Using the arrow buttons on the remote, push the RIGHT arrow ">" ONCE
4..Press the "DOWN" Arrow on the remote ONCE
5. Press the "ENTER" button on the remote ONCE
6. Press the "DOWN" Arrow on the remote ONCE
7. Press the "ENTER" Button on the remote ONCE
At this point you should have your picture and menu displayed on the screen, simply hit setup again to exit, and get the hell out of there!
If you want a copy of what you should be looking for, e mailed, I can do that.
Finally, to do a system restore, which will achive the same results (but you'll have to reset date, time etc.), follow steps 1 & 2 Then instead of hitting the DOWN arrow once, press it THREE times and hit "ENTER" this will restore the unit to factory settings. I have never done this so I am only guesing what other settings you will have to adjust, as well as time and date.
I also have the details on how to make the unit region free, email me and I'll send them to you.
Good Luck!
Posted on Jan 12, 2009
Above the setup button on the remote is the P Scan button. Press that and wha la! It worked for me!
Posted on Nov 04, 2008
I hit the tuner to PAL now i get this lines going up and down...when i hit setup to change back to NTSC nothing happens...Please help!!
Posted on Dec 27, 2008
Just figured it out. If you hold on to the enter button continuously, it will allow you to go beyond the progressive scan selection to the master reset selection at the bottom.
Posted on Dec 26, 2007
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
Does somebody know how to make the LG RCT689H region free. It's a dvd Rewrittable, does someboady has expierience.
Access the DVD setup menu by turning on the unit without a DVD in the drive.
Press simultaneously the "arrow down" button on the right side of the DVD recorder and the "clear" button on the remote control simultaneously for about six seconds to access the options menu.
Use sideways arrow keys on remote control to navigate to OP6. Set value of option to "8F" (for region free) and press "enter" on remote control to save changes.
When message saying "save ok" appears press "menu/list" on remote control to exit options menu. The unit will reboot and is now able to play any DVD.
Mar 28, 2011 | LG BD550 Blu-Ray Player
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Cannot access the "guide" facility "t
i had a similar problem with the 870 model. i reloaded all the channels using the "initial setup" menu and everything was back to normal. charles
Apr 25, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVD Menu selection not available from Setup Menu
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Dec 05, 2008 | Televison & Video
Records ok but after resetting, I don't have audio
My manual says that the MASTER passwordis 1369. You might try resetting the password using this in the current box. I have read of others having trouble with the audio. check and see if other settings got changed. pg 25 of manual says have disc in unit, access the setup menu and try the user default. Also supposed to be a help section in the setup menu. Hope this helps.
Oct 28, 2008 | iLO DVDR05 DVD Recorder
Reading multi zone DVD's
If you forget your 4-digit code
If you forget your password, to clear the current
password, follow the procedure below.
1. Display Setup menu then select an 1 level icon.
2. Use the Number buttons to enter the 6-digit
number “210499”.
3. Select [Yes] then press ENTER. The 4-digit
password is cleared. Enter a new code.
Mar 10, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Remote problem
flip open the door on the remote and press setup and 1 at the same time . this will switch it back to DR-1
Oct 05, 2007 | Toshiba D-R2 DVD Recorder
How to finalize
i have spent 2 months looking for this answer myself... and at last success! i downloaded the user manual from funai(they made this model) available here: http://www.funai-corp.com/6pdf/om/MWR10D6.pdf on page 38 it instructs you to press setup on your remote, from the drop down menu you need to select disc edit and then select finalize. this aggravated me at first because nothing happens when i hit the setup button, i powered off the unit and hit setup before the disc loaded. this step is not mentioned but is necesary. you cannot finalize a disc after it has loaded to the title menu.
Jul 25, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Protron PD-DVR100 DVD Recorder Logo
345 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
