Question about Heavy Machinery
My flymo hedge trimer is working but not cutting it is a eseicut 510
    Problem Solver:
  • 12 Answers
Probably need to sharpen the blades. Take it to a repair shop around town and they will sharpen the blades for you...............
Posted on Oct 13, 2009
HOW DO YOU REMOVE THE COVERS, THAT ENCOSE THE MOTOR ETC., FROM A FLYMO EASICUT 510? . I HAVE REMOVED ALL THE SCREWS BUT THE COVERS WILL NOT COME APART. HELP PLEASE.
Have you removed the screws that hold the clear hand guard on.? They should just pop apart once all the screws are out.
Jun 22, 2011 | Husqvarna Garden
I have a Flymo Sabre cordless hedgetrimmer, which has stopped cutting anything although the blades still move. What can I do to fix it?
If there are screws or bolts holding the blades together, check these are tight, but not tight enough that the blades can't move relative to each other. If the teeth aren't sharp, you can buy a small flat file to sharpen them. This is a tedious process and both cutting edges of each tooth need to be sharpened.
May 11, 2011 | Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
1984 B&D double sided hedge trimer stops and
The only thing that i can think of is that somwhere along the length of the cable it has either atiny nick or it has been pulled so that when you hold it in a certain way it works . It is most likly near the tool end rather than the plug end.Only way to find it if it is is trial and error turn machien on and bend cable till it cuts out
Jul 28, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
I have a flymo easi-trim electric hedge cutter that has not been used very much. When went to use it gave a loud high pitch squeel, this happened a couple of times before it started-up. But then it would...
when u say not been used verry much do ya mean it's possible it sat long enough for a mouse or two to make a nest inside the motor? LOL.
seriously tho it sound's to me like the motor just burned out. Personally I would recommend investing in a gas powered hedge trimmer. they last longer and do the job better plus there's no chance of accidently cutting through the extention cord.
Nov 05, 2009 | Garden
Homelite trimer 18.0v charger, battery, yellow
homelite 18.0v battery charger, yellow amd green light on,won't charge,lost manual.
Sep 12, 2009 | Homelite Garden
Hedge trimmer not cutting
Try getting the blades sharpened. Also have them checked to see if they are tight together, sort of like a pair of scissors. If the screws holding the blades together are sloppy the blades can't cut.
Jun 22, 2009 | Garden
How do I sharpen my trimmer
WITH A FILE FRONT REAR ON BOTH SIDES.
POSITION BLADE BY ROTATING MOTOR FAN.
Jun 14, 2009 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Heavy Machinery Logo
99 people viewed this question
Top Heavy Machinery Experts
Tom Chichester
Daryl Gleaton
Bill Boyd
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
