Question about GE DBSR453EBWW Electric Dryer
Ge dryer just stop working is there a circuit breaker in the dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it Runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Motor/Blower/Thermistor/Thermostat Removal—
1. Disconnect power supply to unit.
2. Remove Top Cover.
3. Remove Front Panel.
4. Disconnect wiring from Moisture Sensor.
5. Remove three screws inside drum retaining Blower Duct.
6. To remove Thermistor or Thermostat, disconnect wiring from component(s) and remove retaining screws.
7. Remove nine screws retaining Blower Cover panel.
8. Remove Blower Cover Panel.
9. Disconnect Motor Harness connector from Motor.
10.Rotate Blower Assembly as shown to remove from dryer.
11. Remove Blower Wheel by placing a wrench on the rear of the Motor shaft and the nut on the Blower Wheel. Rotate counterclockwise to loosen.
12. Remove three screws from Blower Scroll.
13. Remove Motor locking collar front and back to remove Motor.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 20, 2009
  • 153 Answers
Basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My GE Dryer just stopped
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
SOURCE: GE Dryer model DCL333EAOWW that will not start
I have a GE (Model #: DCL333EAOWW) Dryer that will not heat up properly and the timer does not work
Posted on Jan 16, 2011
Had electrical circuit breaker (240v) change out.
check where the pigtail connects to the drier.
Dave
Feb 22, 2010 | GE DBXR463EBWW Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
GE Harmony dryer does not power on. Light works-
This is an easy check, and it might fix your problem, though it also may be something else. Turn the circuit breaker for your dryer outlet off, then back on. The circuit breaker will be located in the main breaker panel of the house. It should be labeled "dryer" or something like that. It will be a double breaker, meaning that there are two breakers tied together physically.
I am wondering if one of the two breakers has lost contact or tripped. That could possibly allow the light to work, but prevent the motor and heat from working.
It's an easy check, and there is a chance this is all that is needed.
There are other possibilities, but this is a very easy noe to check, so why not start here?
Nov 16, 2009 | GE DBSR453EBWW Electric Dryer
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
My electric dryer won't run
99c99e1.jpgThis dude mounts on the heater housing, if it is open the dryer will NOT run. It blows when the vent is stopped up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2008 | Dryers
I get e01 on ge dyrer panel
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Aug 22, 2008 | GE DCVH515EF Electric Dryer
Ge dryer not heating
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Both broken?
sounds like an electrical issue for sure, too coincidental that both would stop functioning at asime time, they are independent units and should work separately . i would check your breakers, perhaps it has partially tripped
Apr 12, 2008 | GE WSM2780W Stacked Washer / Dryer
GE Dryer DBL333EAOWW
Did the Dryer work before? What led to this problem? Most Electric dryers work on 240 Volts. And have their own seperate circuit breaker, usually marked as "Dryer." So resetting just the main cuircuit breaker might not be enough. Did you reset the Dryer C. breaker?
Sep 22, 2007 | Dryers
GE OVEN DOES NOT WORK PROPERLY JBP69SGH2SS
I am not an expert, but this has happened to me. Examine your circuit breaker and see that it provides the amps that your oven requires. If it just barely provides it, then it could be that your circuit breaker is tripping if you have anything else on that line and it is being used. Especially hair dryers. If your circuit breaker is not tripping, you should contact GE or repair service because you may have a "power module" problem. Good luck.
Nov 30, 2006 | GE JBP69 Electric Kitchen Range
GE DBSR453EBWW Electric Dryer Logo
323 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
