Question about Exercise & Fitness
Nordic Track Treadmill Viewpoint 2800 : The belt started slipping when taken to a higer speed. This continues to slip even at a lower speed now.Any help will be appreciated ?
It needs to be adjusted as shown in your owners manual.
There are two allen screws located at the back end of the treadmill. That's where you adjust it. 3 - 4 inches of slack midpoint is just right
Posted on Nov 23, 2009
How do you reinstall the drive belt on a T6.3 treadmill?
  1. Remove the drive belt
  2. Loosen rear roller screws
  3. Remove the screw holding the front roller
  4. Slip out the roller
  5. Slip on drive belt
  6. Put back together in reverse order
Dec 29, 2013 | Nordic Track NordicTrack T6.3 Treadmill
Nordictrack commercial 1600 treadmill drive belt keeps slipping off the front roller.
Hi Brent,
I do suggest ringing Icon Fitness and let them organize a tech to look at the machine.
Dec 12, 2013 | Nordic Track Exercise & Fitness
Nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Oct 23, 2011 | Nordic Track Exercise & Fitness
What can be done when the track slips on my treadmill?
there should be two screws one on each side of the belt in the back of the treadmill (you may need to remove the side rails (theres one on each side of the belt) to see them) those screws will tighten the belt. note: you must be carfull that the belt is tightened evenly. livestrong.com is a great website if you need help wih this. good luck!
Mar 02, 2011 | Nordic Track /proform Treadmill...
When running on our treadmill the belt slips.
Hello, It sounds like you have aslipping front roller pully. Remove the motor hood and watch the front roller while you are on it. Once the belt is moving slowly, try to stop the wlak belt by planting your fett for a second, if the walk belt stops, but the drive belt and motor continue to run, the plastic pully is slipping and the whole front roller will need to be replaced.
Hope this answers your question.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 16, 2011 | Nordic Track NordicTrack A2750 PRO...
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
Viewpoint 2800 the belt is not run
If the incline works but the motor fails to run, the unit has a faulty motor controller.
Jan 15, 2010 | Nordic Track /proform Treadmill...
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Sep 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
550 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
