Question about Kenmore 57029 Side by Side Refrigerator
Freezer frozen--fridge not cold
I read the response posted by someone else and wonder if the problem can be easily fixed by me--or if I will have to call repair
My freezer has ice all over it and my refrigerator is not cold.
For about 2 months before this happened our water in the door was not coming out easily. It would just stop and then finally---after lots of jiggling-give us water.
Could our water filter have anything to do with these problems. I know it needs to be changed. Thanks for any information!
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Sep 20, 2009
Samsung fridge freezer RL38SCSW fridge isn't cooling freezer is fine please help
Hi Hannipan,
I know this is a bit late but it should help for others. We had the same problem with our RL38SCSW (caused by the freezer door being left ajar for the day) the problem is caused by the freezer trying to cool down the unit and goes into overdrive by freezing all the cooling coils in the back. The air can't circulate (via the use of the fan) and so the freezer stays cold but no cold air travels up to the fridge.
Take out all of the freezer trays and behind there is a plastic cover held in by one screw, remove this and carefully remove the cover (the top part needs to be pressed downwards to release) under there is a grey plastic cover this will most likely be frozen to the back so don't pull it. Use a hair dryer and try to melt the ice. Remove two more screws which hold it in place and eventually it should come out easily. Now you can see the coils behind are frozen up, leave them to defrost (don't chip at them! or alternatively use a hairdryer to help melt the ice) Once it's de-iced put it back together and you'll be good to go again.
(Make sure you don't keep the hairdryer and one area of the fridge you'll melt the plastic and also make sure you turn off the freezer at the plug before working on it)
Jan 28, 2013 | Samsung RL38SCSW (113 cu ft
FREEZER IS COLD BUT NOT THE FRIDGE
If your freezer is cold and not the fridge, then your duct is frozen between them. This piece of junk is faulty and Sears has been out 5 times to fix it. They changed almoust all the parts in this fridge, but the problem is still there. Basicaly it does not defrost and the cold air can't get throught the duct. I have to defrost every week.
Apr 05, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer works, fridge is warm
Your defrost timer seems to be bad. Find it at the bottom of the fridge and turn the knob to see if it activates. If it does then it is bad. If it doesn't activate then your element or thermosat is bad. These parts are not to expensive and you can do it yourself and save some big bucks. Be safe and disconnect power before servicing.
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Fridge & freezer not cold enough
EASY FIX. TAKE ALL FOOD OUT OF FRIDGE AND FREEZER AND STORE IT.
THEN UNPLUG YOUR FRIDGE FOR 24HOURS WITH DOORS OPEN.
YOU WILL HAVE TO CLEAN UP ALOT OF WATER. THEN CLEAN THE FRIGE.
WHEN YOU PLUG IT BACK IN IT WILL WORK.
BUT THIS IS JUST A TEMP FIX. IT WILL HAPPEN AGAIN IN ABOUT A YEAR OR TWO.
TO GIVE U A MORE PERMANENT FIX WILL TAKE SOME TIME. TRY THIS FIRST.
Apr 30, 2009 | Amana ARB220ZC Bottom Freezer Refrigerator
Admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Jan 31, 2009 | Maytag Admiral Top-Freezer Refrigerator
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Refrigerator is at80 degress
This unit uses the cold air from the freezer to cool the fridge, you will find that the air duct has frozen up, completly defrost overnight with the doors open, this should rectify fault. Regards Advisor
Mar 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 57029 Side by Side Refrigerator Logo
116 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
