Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
Use the power supply outside the computer
I have an NPS-200PB-73M power supply and would like to use it as a power supply for a bread board for testing circuits. How do I turn the power supply on without the motherboard?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Plug the power supply to desire voltage. Monetarily short the GRAY and BLACK wire in one second.
Posted on Sep 04, 2010
  • electronixTech
    electronixTech Oct 03, 2013
    You also have to put a load across the yellow and black wires (12volt) of the 4 pin connectors. I put a 100 ohm power resistor across the 12 volt pins and the power supply turns on. Just jumpering the gray and black wire is not enough.
There is no green and black wire on this unit
Posted on Feb 06, 2010
  • electronixTech
    Dell power supplies use their own proprietary wiring system. Normal atx supply use the green and black jumpered to run the power supply outside of the case. With Dell you have to jumper the gray and black wires on the 20 pin connector and then put a load such as a resistor or 12 volt car light bulb across the 12 volt yellow and black of any 4 pin connector.
  • 82 Answers
What you need to do is you can put a paperclip into one of the cables to get it to load up just google it i can't tell you the pins of the top of my head
Posted on Sep 20, 2009
No enciende el power suplay
your power box on computer has went bad were your maine power source is.
Jan 30, 2011 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
PC is not booting Dell Optiplex 100
leave me an email address and I will assit you.
Apr 28, 2010 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
What is the 6 pin
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Oct 02, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
No power on
if sb +5 is ok then check one by one these component :-
check main swithing transistor for open
check diode, capesetor and 3.3 ome resitor it may be open after then check
+ 12 to +18 volt for pwm ic and ,
if votage is not missing then change pwm ic
Apr 21, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Dell - nps-200pb-73M not working
dont know the AC and the DC of my NPS-200PB-73M
Apr 25, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
TO bogdan
check the twisted paired wires that are found inside your system unit..usually it has a color red, green, blue and white wires..check your motherboard wire pins usually located at the sides of the board or near the BIOS chip. IF you can see those wires, try reseat those wires( but make sure you have an assistance of a qualified technician to avoid wrong connections and to fry your motherboard).
Goodluck!!
Feb 23, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Computers & Internet Logo
1,424 people viewed this question
Alun Cox
