Question about Canon MultiPASS F60 All-In-One InkJet Printer
Printhead will not return to center. Message I receive is to check printer and push resume button. Have done this there is no obstruction. I have a multipass 730.
Error 5100 what do i do???
Error 5100 points to a "carriage jam"
The carriage is the assembly that contains the print head and cartridges.
This error can be difficult to solve because various things can cause it.
Since this is a new printer, maybe there is some packing or packing tape that is obstructing the carriage.
Verify that the carts and print head are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've n
Sep 08, 2011 | Office Equipment & Supplies
I am receiving a message: ink absorber is almost full. Contact service center.
You reset the ink absorber like that:
1.printer is offline
2.push resume button is red and in the same time push power button
3.do no let resume (red) button,and push the resume button 2 times
4.wait to appears numer zero to the screen
5.them push four times to resume button
6.close the printer and start up
If a have been usefut please give me a vote :).Thanks
Mar 14, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I am getting error message 5100....can't locate the manual...Any ideas? Thanks!
Error 5100 indicates "carriage jam". The carriage is the assembly that contains the print-head and ink cartridges. This error can be difficult to solve because various things can cause it.
Make sure the ink cartridges and print-head are installed properly. Remove them and re-seat them.
Sometimes you have to try this a couple of times, if you've never done it before. If this does not work, unplug, wait 3-4 minutes, then re-plug in.
Jan 15, 2011 | Canon PIXMA iP1600 Printer
Canon pixma mp540 error 5100 . What is error 5100?
dear,
The carriage is the assembly that contains the printhead and cartridges.
Verify that the carts and printhead are installed properly.
If this does not work, unplug, wait 3-4 min, then re-plug in. Enjoy..
Sep 21, 2009 | Office Equipment & Supplies
It is coming up with error 5100. do you know what his means?
If its making noise it is definately not a registry/software issue. It may be caused due to a misfeeding/carriage/calibration issue. Thank you Sir, Have a nice day.
Sep 19, 2009 | Canon PIXMA MX310 All-In-One Printer
My Canon BJC-85 Printer beeps 3 times and the cartridge printhead comes to the center and the green power light continues to blink. I have replaced the cartridges I have replaced the printhead with the...
3 beeps is still telling you that the printhead has a problem. Did you put in a new printhead? You also have to tell your printer by holding the resume button for the correct amount of beeps to set it for the printhead you have installed.
Jul 23, 2009 | Office Equipment & Supplies
I have a Canon i560 printer and it keeps coming up with error 5100. what do I do?
goodluck hope it works
Sep 21, 2008 | Canon Office Equipment & Supplies
Error
Service mode reset - but beware resetting the counter without replacing the waste ink absorber may cause ink to overflow out of the printer.
1) With the printer power turned off, while pressing the Resume/Cancel button,
press and hold the Power button. (DO NOT release the buttons.
The LED lights in green to indicate that a function is selectable.) .
2) While holding the Power button, release the Resume/Cancel button. (DO NOT
release the Power button.) .
3) While holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in
orange and green, starting with orange.) .
4) When the LED lights in green, press the Resume/Cancel button 4 times. (Each
alternately in orange and green, starting with orange.) .
5) Press the Power button. The LED lights in green, and the reset is performed.
(When the operation completes, the printer returns to the
menu selection mode automatically.) .
6) Press the power button to exit service mode.
Note:- if you accidentally press the Resume/Cancel button more than 4 times in
step 4 then just press the Resume/Cancel button at least 10
times and the printer will be returned to step 4 automatically.
BTW the other functions that are available at step 4 are -
press 0 times = power off
press 1 time = Service Test Print
press 2 times = EEPROM information print
press 3 times = EEPROM initialisation
press 5 times = Destination settings (country information, do not play with
this)
press 6 times = Printhead Deep Cleaning
press 7,8 or 9 times = not used in servicing so do not play with these.
press 10 times or more = return to menu (step 4)
Jul 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
LCD Error: "Check Printer"
I FOUND A SOLUTION that worked for me for the CANON F50:
F30/F50 Printer
1. Enter Service Mode - by pressing "menu then copy then #"
2. Select TEST MODE
3. Select (8) PRINTER TEST in TEST MODE
4. Select 3 (EEPROM CLEAR)
5. Select 0 (INK COUNT)
6. Press Stop/Reset key
7. Press On/Off Key
Jun 03, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
Canon MultiPASS F60 All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
