Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
The ink on my printer does not do right
The ink on my printer does not do right the color is not right if you are trying to print something with purple in it it will turn yellow and blue and then the other color are all blur
  • 295 Answers
Kindly go to the kodak home center and go to maintenance option after clicking on help [?] on the top most right hand side. click on clean printhead . again try to print .if the issue is not solved,contact Kodak,they will replace the printhead for you free of cost.
Posted on Sep 21, 2009
  • 82 Answers
Go into printer setings and do a test sheet if the clolours are not in diffent shades its becasue ink is low
(the ink level meter dosnt work with colour ink becasue it covers whole cartridge me for example it says its half full yet i know its nearly ussed up all blue ink
Posted on Sep 20, 2009
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
My color inks are out of ink but still in the printer...i just replaced the black ink. when i try to print, it will not allow me and says to replace the color inks first. i followed the instructions to...
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the color ink.
Note: Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality if you want to print color in the future.
Sep 23, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
My printer will print black ink, but when I try to print something with color, nothing appears. I have tried re-installing the color cartridge and restarting the printer. The test page says all ink levels...
I had the same problem. Unfortunately, it may not be fixable. The tiny pipes that carry the ink are REALLY small; about the thickness of a hair. As a result, they can clog. If you only occasionally print in color, the ink in the pipes dries out. You can't do the repair. I was told by the technician that I should print the test pattern occasionally, if I'm not printing in color often.
Jan 16, 2011 | Office Equipment & Supplies
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
Jan 09, 2011 | Epson Stylus C88 InkJet Photo Printer
To save colour ink, it was turned off by my daughter and i cant figure out how to turn it back on
goto control panel goto printers right click to select your printer click on properties look for the TAB for color select the checkbox to print in Color click OK.
You can also try printing something when the printer box pops-up right click on your printer select properties click on the TAB for color click the checkbox for color click OK click OK to print.
Sep 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Print quality with black ink is poor throughout the page
hi, i have one of these to, mine is still running on the "test" inks as well but i have all colours in mine, anyway i digress, you can try, going to print something , when the chose printer box apears, choose cpl300 then choose properties ( to the right ) then choose graphics thumbnail, on quality choose best, then at the bottom you will see advanced options, then just click print all txt black, and click darken txt, and that should give you nice black txt....hope this helps
Mar 15, 2010 | Samsung CLP 300 Laser Printer
How to print in black and white only
Goto Control Panel > Printer and Faxes > Right Click > Printer Prefernces
(on your desired Printer)
A dialogue box will appear, now from here every printer got a bit different tabs.
Even though its too easy to find somthing like "color".
Under such tab you will find options like
  • Color Printing
  • Gray Scale
  • Black Ink Only
  • Toner Saver mode (For Lasers)
So select the Black & White option, and its done.
Do Rate Me!, If helpful.
Jul 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Printer
I had same problem it wont print with just black even by using the settings.You can trick it into thinking the color cartridge are full by taking out the color cartridge and taping over the clear part of the cartridge were you can see the level of ink.Thats how the machine knows weather or not the ink is full by looking through the glass by either light or some other way and if its blocked it thinks its full.
Sep 05, 2007 | Office Equipment & Supplies
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
157 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
