Question about Garden
Troy Built TB575SS what is the main fuel line size?
5 Suggested Answers
  • 61 Answers
SOURCE: What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Posted on Apr 14, 2010
Testimonial: "Thanks for the tip, I will try that when I find out the fuel line size."
rycgl
  • 1545 Answers
SOURCE: have a troy built TB575SS trimer. Pull cord has
The starter recoil spring may have possibly broke or the rope is hung up somewhere on or in the pulley. A lot of these units are assembled using Torx (Star) head screws and disassembly requires a couple different sizes to accomplish. Take your time...you will see the screw heads, but reloading a starter spring for a trimmer is a little tricky and you may need help doing so, but you can fix this yourself.
Posted on Jun 11, 2010
SOURCE: Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
Posted on Apr 09, 2010
SOURCE: how do i remove the
If you are talking about the side where the clutch is, there is a Torx screw inside the hollow part of the clutch housing. Using a #20 Torx bit, loosen screw. If this is the first time on this screw it will be tight and the drive shaft will turn with it. You will have to remove top of cylinder head and put something soft inside the cylinder to stop piston from moving up and down; usually a towel and something stiff like a screwdriver to hold it from moving.
After clutch housing is removed, the clutch itself is threaded and by holding the shaft with pliers you can unscrew the clutch.
Past this, just screws holding the plastic housing.
Posted on Nov 28, 2010
Clogged fuel filter
take the line of the carby and check the fuel flow first
indicates that the carby is not filling ( jammed needle and seat) or the main jet is blocked
Jun 29, 2017 | Troy Heavy Machinery
Is there something that can be put in the fuel to keep the fuel line from disintegrating?
You can add a fuel stabilizer to the fuel to prevent that from happening. You should always add the stabilizer to new fuel and it can be used in all of your engines, everything from a string trimmer to your car. The ethanol in today's fuel is causing many problems, especially with 2-cycle and 4-cycle engines. You can buy Star Tron fuel stabilizer from PartsBuggy.com. A good size is the 8 oz bottle. It treats 48 gallons of fuel with one bottle.
Nov 30, 2012 | Troy Garden
Do you mix the gas and oil together with the Troy-Bilt4 cycle TB575SS. Lost directions. Thank you
No. You do that for a 2-stroke engine. Your engine should have oil in the crankcase and you just need to check the level of it and add gas to it like a regular lawnmower engine.
Sep 06, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Have a troy built TB575SS trimer. Pull cord has lost tension and cord is just fully hanging out. How do I I take unit apart to re-adjust cord tension?
May 29, 2010 | Troy Garden
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Jun 15, 2009 | Troy Garden
Garden Logo
716 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
