Question about Electrolux ICON Designer E30SO75ESS Oven
I have baked on aluminun foil on the bottom of my self clean oven did the cycle to self clean and the aluminum foil is still stuck on the bottom what can I do to remove it without ruining the surface
    Brigadier General:
  • 3,006 Answers
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
Posted on Sep 20, 2009
  • 3 Answers
Where do you buy this caustic soda?
Posted on Apr 13, 2012
1How do I remove small pieces of aluminum foil which are stuck to the bottom of my oven? 2 If I can't remove the small amounts of alum. foil, Will still be able to use the self-cleaning feature?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
You can try to use a putty knife.
When your oven goes into the self cleaning model, you are burning off grease. The burning off of aluminum foil is nothing compared to burning off the grease.
You may see some small flame. But, this will soon pass. Your cleaning cycle can handle this without causing any damage.
Mar 24, 2015 | Kenmore Ovens
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a new Frigedaire self cleaning oven. Before I got to read the manual my daughter baked a cake which dripped onto the oven floor and began to smoke. To catch more drips I put a pice of tinfoil on...
Greetings,
remove as much tin foil that is possible...use something like hot water and mild detergent to loosen up the baked on cake residue...this should come up ok with alittle elbow grease...then run your self clean cycle...All will be ok....Bruce Denton
Jan 20, 2011 | Frigidaire Ovens
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
Some aluminum foil melted onto the bottom of my Kenmore Elite oven, which happens to have a hidden bake element. I happened to catch that this was happening to remove most of the piece of foil, however,...
Don't use self clean. Get some easy off oven cleaner. Self clean gets too hot and ruins expensive delicate electronics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 07, 2010 | Ovens
I am having the same problem that many others are. My screen went blank and when the buttons are pushed they just beep. This sounds as if it is some sort of malfunction within the circuit board? I plan to...
It is and you are doing what you should. We know that a lot of these problems are being caused by the heat from a self-cleaning cycle rising up into the circuit board. I get a lot of these problems right after someone self-cleaned their oven, although it can fail completely months after the cleaning cycle damaged the board. So in the future try and use the self-clean cycle very sparingly and set the timer to clean for only two hours if it will allow it. My best advice is to not use the self-cleaning clycle, use aluminum foil in the oven floor, and hand clean the door and walls as you use it. Do not use oven cleaner on this as most of the cleaners will damage the self-cleaning oven liners. Change the aluminum foil when it gets dirty and never self clean with the aluminum foil in the oven. Good Luck, Appliance Specialists
Jan 05, 2010 | Whirlpool GBD307PDS Electric Double Oven
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Electrolux ICON  Designer E30SO75ESS Oven Logo
728 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
