Question about Kirby G6 Bagged Upright Vacuum
How do i put the belt on my kirby sentra - Kirby G6 Bagged Upright Vacuum
  • 430 Answers
See my previous detailed posts for a Generation 5 and follow step by step.
Posted on Sep 20, 2009
THE BRUSH ROLLER WILL NOT TURN---i HaVE REPLACED THE BELT AND CLEANED ASSEMBLY---I HAVE KIRBY SENTRA
There may be dirt, hair, etc. lodged inside the end caps. Remove the brush roller and remove the end caps to check.
May 11, 2017 | Kirby Vacuums
THE BRUSH ROLLER WILL NOT TURN ON MY KIRBY SENTRA
That is an expensive vacuum cleaner. If it were mine I would have it serviced by a Kirby vacuum serviceman.
May 11, 2017 | Vacuums
How to put a Kirby Vacuum belt back on New belt seems too short
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Jan 27, 2010 | Kirby G5 Bagged Upright Vacuum
Belt is on brush won't turn on kirby sentra
either its broke or the belt removal switch you urn to access the belt is not back in belt tension position
Oct 14, 2009 | Vacuums
How do i put on the belt for a kirby vacuum cleaner?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=793952
Generic problem for all Vacuums
How do I put on
Posted by emccall3 on Jul 17, 2008
How do I put on the belt for a Kirby vacuum cleaner?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Putting a new belt on on my kirby sentria
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=780370
Posted by cowangelgirl on Jul 14, 2008
Putting a new belt on my Kirby Sentria
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
1-800-494-8586
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 14, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Sentra vacuum burning belts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=565459
posted by campoclan on May 02, 2008
Have had Kirby vacuum for a couple of years since I've had it I burn at least two belts in two months. I keep roller clean, what is the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the problems that people have is that they feel they have to have the vacuum head all the way to the floor and that makes the belt work that much harder. The key to the best cleaning is to raise the height adjustment all the way to the top and once it’s there then drop it down one notch or setting @ a time until you here the tone change. Then try it to see if the vacuum if picking up well if not drop it down one more notch and that should be the setting it is supposed to be for your type of carpet. And remember to use the genuine Kirby belts instead of the Kirby replacements, they will work better. And your suggestion that to keep the brushroll clean and free spinning on each end and also keep the bottom plate clean of dirt and grease because if there is a build up it will move slower and leave black marks on the carpet. I hope this will help and if not contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
May 02, 2008 | Vacuums
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
