Question about Zenith DVP615 Portable DVD Player
DVD Disc not working
My player says that it is 'loading', then says 'check disc', but works fine with music CD. can anybody help? is it even worth to get it repaied by professional?
  • 1 more comment
  • roanco Dec 17, 2007
    The player initially worked for all region. If this is really the issue, is this something that can be fixed? Or is this related to the firmware issue which means that it's a junk now?
    Thanks
  • max848 Dec 22, 2007
    Just purchased Hairspray and it will not work in Hitachi or a relatives Zentih player. However works fine in floor model of a TARGET player. What is going on with new DVDs...first time had this problem have lots of dvd's
  • Anonymous Mar 15, 2008
    My dvd player spins, but just says loading and then check disc. Not that old... any solution?
Check regional code
Posted on Dec 15, 2007
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Dvd-audio cd burning issue
If you are burning a "Data Disc" (the burning software should tell you or have you select it) then music will NOT work on a CD-player. It will only work in another PC.
Data disc is for files, pictures, videos, music that you want other COMPUTERS to be able to read and play.
If you want a music CD to work in a car or something like that it NEEDS to be burned as a music disc, not data.
Hope that helps.
Mar 17, 2009 | Gateway GT5056 PC Desktop
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
CAVS DVD 105G having trouble reading super CD-G disc
just got the CAVS 105G and the tray will not open.  Could there be a shipping brace that needs to be unfastened in order to open the tray?
Jul 09, 2008 | Cavs DVD-105G
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Wrong Disc
probally a bad or dirty Laser.
clean the laser by using a cotton swap with alcohol on it and rubbing it lightly
if it doesn't work, but a new one, cobby isn't worth repairing.
Mar 03, 2008 | Televison & Video
Dvd player
Not a disc cleaner you need but a lens cleaner. If that does not work then there are electronic or mechanical problems and most likly not worth repairing.
Sep 30, 2006 | Bush DVD2038 DVD Player
Zenith DVP615 Portable DVD Player Logo
105 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
