Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Installation of router
The installation wizard does not tell me how to install the router.
  • 556 Answers
There are many versions of this particular router. use the following link to determine the router version.
Dlink.com
Select Canada
Click Support
Click Product Information
Under Broadband, Under Routers click WBR-1310
FInd you revision number using the label below the router and report it back here, if you need more help
Click on the appropriate picture
In the left column there is a product manual and a
link to download adobe reader, if you need it to read documents from this site
In the center there are Quick Router Setups that may help.
There are how-to's on the bottom of the page that may also help.
Posted on Dec 15, 2007
2 Suggested Answers
  • 128 Answers
SOURCE: I lost the installation wizard
Go here and follow the steps under support resources
http://www.dlink.com/products/?pid=474
Posted on Jan 19, 2011
Downloading set up wizard
You are trying to install the router??
If you have driver then you can install the router easily or you can download from manufacturer website and install it.when you install it, setup wizard will automatically come...
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 17, 2013 | D-Link Wireless N 150 Home Router 4Port...
I have just purchased a Belkin N600 modem router. I have attached my Canon i850 printer to the USB port on the router but I cannot print. The green USB LED is not illuminated. Can you help, please? ...
I think you need to connect your printer to the router using an ethernet cable and not a USB cable. Ethernet cables are plug-and-play cables and doesn't require you to install a software. If you really need to connect your printer using a USB cable, you need to connect it to your PC so that the PC will run the installation wizard to install the USB cable. Of course the router cannot run installation wizard to the printer or the printer cannot run installation wizard to the router.
Sep 11, 2011 | Belkin Play N600 Wireless Dual Band Router...
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I was wondering if i could get the install wizard for my router i lost it
The best way to get the install wizard to run is to re-install from the CD-Rom, as it should include a short cut to it.
Sep 26, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
What happens if u connect the wireless g router before installing the cd
with XP, the drivers are built in - so you should be ok. If not, open your system manager, and delete the router, unplug it, restart the pc and install the disc first this time.
Dec 28, 2008 | Linksys Wireless-G Broadband Router
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
Easy Install wizard problem
What you can do to fix this problem is not use the install program at all.
To configure your router, in your web browser's address bar, put the IP address of your router (Another belkin router's default IP was 192.168.2.1 out of the box) and click on go. This should bring you to the routers setup, and the password by default is blank.
May 15, 2008 | Belkin (F5D7230-4) Router (587009)
Unable to access the set-up wizard to install my wireless router.
just reset the router... do you know how?
there is a small hidden button on it that you must press and hold for some minutes firs with the router powered and then with the router not connected to power line... Try this at leas 2 times with and 2 time without power, then try accessing the router as if it were new... with the default pass that comes in the manual...
Mar 03, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
Sep 19, 2007 | Buffalo Technology Buffalo AirStation...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
98 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
