Question about Dryers
Not drying clothes - have heat and tumble but probably not air Kenmore 80 series dryer.
    President:
  • 512 Answers
Your vent is clogged. Remove hose from back of dryer and wall. vacuum out back of dryer, dryer hose an vent pipe in wall, if it goes out at roof you will need to clean out. Moisture from dryer is getting caught in excess lint trapped in vent causing dryer not to dry.
Posted on Sep 20, 2009
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
My 80 series Kenmore Dryer is heating up, tumbling, but my clothes aren't drying. It's taking 6-7 cycles to get anything dry, I have checked the vent hose and everything. All seems to be checking out ok....
You need to check your vent, or your vent system in your dryer. You also need to check to see if your clothes are tumbling. If not then your belt could be broke. Good luck!
Aug 21, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
My 80 Serie Kennmore dryer will not dry my
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
Good Luck!!
Thanks
Jul 08, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
201 people viewed this question
Top Dryers Experts
