Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP-65wv600 problem
Turn tv on, you get a green screen which turns bright white for about 5 seconds, then turns black. Has good sound but no pic. Sony authorized TV repairman says all three CRT tubes are shot and it will cost $900 to get them fixed.
He temporarily got the icture working by taking the fron cover off and tapping three areas a bit and bam - pic comes on. Says it might last a week a day two weeks etc., but not long. I have until after christmas before I have him back to do the job, cannot afford to pay $900 at Christmastime! Please help!!!
  • Doubler Dec 15, 2007
    Thanks ctf1800. I will call Sony and look into this. Thanks again for posting. Happy Holidays to you and yours!
  • 4,402 Answers
I hope this is whats happening with your set if it is and it sounds like it keep after sony!
Sony received reports of flickering on select rear projection TV models and immediately started an investigation. Sony's engineering team found that in a small percentage of sets (less than 1%) made with impregnated cathode CRTs, the material used to impregnate the cathode may attach itself to another section of the electron gun and cause a mild brightness fluctuation or change in hue.
Once this problem was diagnosed, Sony published a Service Fix for this issue and authorized Sony Service Centers and Authorized Service Centers to make modifications and replace all 3 CRTs in affected units at no cost to the consumer in order to resolve the issue. In addition, a change to the manufacturing line was made to ensure that current units do not experiencethis problem.
If a consumer is experiencing this symptom, contact Sony Call Center (800-222-SONY) to schedule a service call. Sony has extended the warranty on these models for this issue and is working with authorized service centers, providing all current information for the repair as well as assisting them in ordering the parts beforehand, so the repair can be
completed in one call.
Posted on Dec 14, 2007
T.V. comes on show blue then goes out after 3 second and only hear sound
When it comes on with a blue screen is it rather bright and or has curved faint trace lines in the picture?
Dec 12, 2012 | Sony KP-65WV600 65" Rear Projection...
Have a Sony KP-65WV600, already replaced d board once, and replaced convergence ic's once also. Now as soon as I turn unit on, turns to red screen and shuts off, video that is, audio works ok, noticed...
Check High voltage Block.After replacing ic's (STK convergence ic's) you need to adjust Black&White scale.Turn ALL screen adjustments to min.Turn TV on and adjust screen slowly for each gun (I would start with Red first ) when you came to point that you see red background with white lines across, at that point G2 is too high (that will cause TV to shut down,don't worry just lowered adjustment and turn tv back on) so adjust to proper voltage and do the same for each gun.After that, adjust focus for each gun (again all controls are on High Voltage Block and HVB is mounted on front of your tv after you take speaker gril out) black box with 6 controls' screen RGB, focus RGB .
You should do that in dark room in order to get perfect Black&White scale,when all guns are adjusted properly you will see grey picture.Make sure 'Color" adjustment on your display is down to 0. Another step is convergence adjustment ,Flash Focus etc.If TV stil shuts off after all, your Red picture tube is short inside,take crt pcb from tube,make sure TV is unpluged from power before that, and turn Tv on .If stays On tube need replacment...good luck)
Aug 22, 2011 | Sony KP-65WV600 65" Rear Projection...
KP-65WV600 Red and Green Lamps fade out after about 15 seconds
Hi, if the tubes fade from full brilliance to black over a few seconds, the possible sounds like dry joints in the CRT heater circuits. possibly caused by dry joints (bad solder joints). Most repairs involving rear projection TV's can be a pig (mainly relating to access to work on the circuit boards)
Sep 23, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
My 65" sony rear projector
shorted green tube sony had major problem with Tubes
May 27, 2010 | Sony KP-65WV600 65" Rear Projection...
Turn your screen drive down to green and blue tube.
You have a focus/screen drive control block that you can adjust each tube R/G/B
Mar 17, 2010 | Sony KP-65WV600 65" Rear Projection...
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Green screen
sounds like your green crt is shorting let me know if you need more assitance or if you would like to know where you can purchase a crt at.
Apr 10, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Green hue
GO to service mode ,On std by mode press diplay-5-volume plus-power button on remote con.
reduce green drive to balance .For good adjustment you need white picutre .Also reduce brightness to noticeble lavel.
Sep 12, 2007 | Sony KP-51HW40 51" Rear Projection...
I have the 51" rear projection (kp-51ws520) and problems...
The same problem?? Sounds like a green crt driver is defective or the green crt is bad.
Aug 14, 2006 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
