Question about Dryers
Automatic Dry Function Has Stopped Working
Dryer's heating element works fine. Dryer has an ''automatic Dryer'' selection that is suppose to turn the dryer off when the clothes are dry. This has worked for several years and now the dryer just runs forever, clothes still dry but does not shut off
Dryer is a Whirlpool LGR7620LWO
  • totocrab May 11, 2010
    did you fix this? i have the same problem/question for a kenmore dryer. i think it's the timer but how do i verify/fix it??
  • 430 Answers
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Posted on Sep 20, 2009
Whirlpool wed4815ew1. Timed Dry works, timer advances. Automatic Dry does not. Plenty of heat, clothes dry fine. Bought new timer W10185982 STILL doesn't advance
Hello David. We regret to hear about your Dryer not working on select cycles. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If that does not help then we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 08, 2017 | Whirlpool Dryers
The dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
If it's not making heat the humidity sensor will never dry out, therefore it keeps running. It sounds like your heating element is bad.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
Dryer is not drying
well sounds like 2 different problems happening at the same time the automatic dry setting not shuting off is the switch and the not drying is the heating element going bad
Mar 19, 2012 | Dryers
Dryer won't heat up or advance timer but drum still turns
When any automatic cycle is selected heat is required for the timer to advance. Timed dry should advance with or without heat. You should check your heating element for continuity as well as all thermostats. Location of these components depends on the brand name and model.
Jan 11, 2011 | Whirlpool Dryers
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Newer Kenmore dryer automatic sensor not working.
I dont understand your problem?
Jan 19, 2009 | Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
154 people viewed this question
Top Dryers Experts
Marvin
Marvin
