Question about Dell Inspiron B130 Notebook
Invalid Configuration information
I have another B130 with problems. (Did they ever make a model like this that had no problems?) When I turn the power on the meter bar shoots across and then goes into this screen and says Invalid configuration information-please run setup program. When I first turn it on there is no F2 or F12 appears on the screen. Any ideas how to get into setup?
  • sodak222 Dec 14, 2007
    I cannot get it to go into anything! t just goes from the dell logo screen to the message about having Invalid configuration information and then stops there. Is there any way to make it get into the setup screen?
Thank You for the advise. I will contact Dell for help on this problem. This computer was given to me but had no discs with it.
sodak222
Posted on Dec 14, 2007
  • 383 Answers
Windows Registry help First, get the computer to a MS-DOS prompt. Information about how to get to a ... that contains information about the current configuration of hardware ...
FTP information and help
Information about FTP and its commands. ... If you are unable to connect to any address, it is likely an issue with the network or computer configuration. ...
Device Manager information and help See our overview section for additional information on how you can get into ..... but the configuration information in the .inf file is set to hardwired. ...
Good Luck, Please dont for get to Vote.Thank you
  • sheila skaggs Dec 14, 2007
    To get your computer back up and going with out any trouble id just re-store the computer with the cd's that came with your computer when ya very 1st bought your computer, sorry but this is all i have for ya with out going to in to deep problems futher, Restore ........ call your Dell computer manufactor and ask them to help ya re-store your computer will be no charge for re-storing and they will help ya. or use the cd's that came with your computer and follow instructions .
    Good Luck.
Invalid System Board
Open the BIOS, is the time correct? Consider replacing the CMOS battery. You didn't mention the Make , Model of computer or the OS.
Jan 04, 2013 | Computers & Internet
Start your computer and after the BIOS screen disappers , begin rapidly pressing PF8 until the Windows Boot Options appear. You should see "Safe Mode", "Boot from last valid configuration", and "Normal Mode", and maybe a few others. Select "Last Valid Configuration." Computer should sucessfully boot.
Jan 17, 2012 | Microsoft Windows XP Home Edition...
Invalid configuration information-please run SETUP program
Here is what you do, go into the BIOS setup, usually you press the DEL key OR F2 or whatever your one is, IT should say on screen as it boots up.... it says "Press YOUR- KEY Key for SETUP". So, get into setup, using your manual ensure it is set correctly. Then SAVE SETTING and exit All should be good now.
Feb 06, 2010 | Dell INSPIRON 6000 CENTRINO...
Dell B130 Laptop BIOS LOCKED
On alot of motherboards, and I don't know if I would have access to this one or not, there is a set of 3 pins coming out of the board itself, usually with a jumper on 1-2 position. Somewhere next to them, maybe some text like PWD CLR ? Usually, moving the jumper to 2-3, clears the password on the BIOS, as a failsafe back up. If it does look, 'comfortably' like that, don't change anything else. It usually takes only a minute, under battery power, to clear it. Once done, move the jumper back to the 1-2 position.
If you don't see it clearly, write back and I'll see if my Technician access allows for the detailed info. Also, please include the Model # amd Make of your Dell unit.
Respectfully,
Toby White-Beebe
P.O. Box 474
Penryn, CA. 95663
(916) 300-9410 Cell
(916) 473-7409 Home Fax
2008 VA Certified NACI Low Risk Security Clearance
2008 VA OCIS/ROB Affirmation of Compliance
2008 VA Certified OIT Contractor
2008 Dell Certified Lead Systems Expert - DCSE
1999 A+ Certified Service Technician
Aug 09, 2009 | Dell Inspiron B130 Notebook
How to know dell 370 precision battery
If the battery is changed, that will mean that the BIOS was set back to january 1 1980.
Go into BIOS, set the clock to the correct time.
For DELL 370 precision , here is the BIOS instruction:
http://support.dell.com/support/edocs/systems/ws370/
Replacing the Battery caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. notice.gif NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface on the computer.
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
The battery may need replacing if you have repeatedly reset the time and date information after turning on the computer or if one of the following messages appear:
Time-of-day not set - please run SETUP program
or
Invalid configuration information -
or
Strike the F1 key to continue,
F2 to run the setup utility
To determine whether you need to replace the battery, reenter the time and date in system setup and exit the program to save the information. Turn off your computer and disconnect it from the electrical outlet for a few hours; then reconnect the computer, turn it on, and enter system setup. If the date and time are not correct in system setup, replace the battery.
You can operate your computer without a battery; however, without a battery, the configuration information is erased if the computer is turned off or unplugged from the electrical outlet. In this case, you must enter system setup and reset the configuration options.
Jul 03, 2009 | Dell Precision 360 PC Desktop
No images from laptop to pc hook-up
you need to change the tv to pc and you have to go to display properties and under settings click on the little monitor with the 2 on it and check one of the boxes that say use this device as my primary monitor or extend my windows desktop onto this monitor. try that
May 07, 2009 | Dell Inspiron B130 Notebook
Will not start windows and attempted last know good configuration but no success.
You either have a corrupted windows file or a virus.
There is no way of making progress without a windows cd. If you get one be sure to run the repair option.
May 01, 2009 | Dell Inspiron B130 Notebook
Dell inspiron 6000 invalid configuration information
ok wen you turn on your pc can you see anything on your screen ?
number letters ? anything ?
an for how long ?
can you describe with more detail whats going on wen you turn the pc ?
Aug 26, 2008 | Dell Inspiron 6000 Notebook
Toolbar EULA
Press Start then run then type 'msconfig'to bring up the system congiguration utility, then click on the end tab called 'Startup' and look down the list for the EULA programme that starts and un tick it. Re- start and next time it starts up tick the box that says 'don't show again', because you have changed the configuration
Jan 12, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
885 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
