My aircondition blower fan not work - Heating & Cooling
  • 277 Answers
It is either the capacitor or the start windings on the motor. Since a capacitor is about $5 and a motor is $100 I would try the capacitor first. Be careful, capacitors hold voltage so even if the electricity is turned off you could still get shocked by touchung the leads. You discharge a capacitor by using a screwdriver to touch both leads. If it is holding voltage you will see small spark. Once you do that, it's ok to touch them
Posted on Sep 20, 2009
Were is capacitor located on carrier unit mod#38brc060350
Posted on Apr 19, 2010
The fan of air condition is not working?
What kind of vehicle? You can often times smack the box that the blower motor is mounted in and it will often stay working again on many vehicles. I've been lucky a few times
Dec 19, 2015 | Cars & Trucks
1995 Toyota 4 runner airconditioning only works when fan switch set on high
IF BLOWER MOTOR SPEED ONLY WORK ON ONE SPEED.BLOWER MOTOR RESISTOR BAD OR AC/ HEATER CONTROL SWITCH IS BAD.
Sep 09, 2011 | 1995 Toyota 4Runner
I have a Bryant Model 340MAV and the airconditioning fan is loud when running but seems to operating fine otherwise..fan is running and cooling great..the oustide coil was replaced in April. Please advise
Sounds like the motor is going bad in the air handler/furnace now...
Open up the blower compartment and spin the blower by hand with the power off...you should be able to hear if the bearings are rough or if the blower is hitting something... then you will know what you need to fix...
heatman101
Aug 29, 2011 | Heating & Cooling
2006 Beetle aircondition multi speed main fan has faulted out? The fan was loud in high speed for about a month and now only works sometimes. When fan not working there is no air condition and we got 108...
the bearings in the blower fan is out just replace the fan . remove the scews holding fan in and unplug it and it pulls out these are around 45to 60 for the fans
Jul 31, 2011 | 2003 Volkswagen New Beetle Convertible
Heater/aircondition fan motor, will not stop running (FAN MOTOR PROBLEMS)
This is very common i've done tons of these, its the blower resistor module, replace the blower resistor module and that will solve your problem. this part is located under the hood on the firewall on heaterbox, this costs about $200.00 for the part and heres a picture of it. hope this helps.f2aa535.jpg
Sep 13, 2010 | 1989 Cadillac Sedan DeVille
2003 Dodge Durango airconditioning blows hot air.
The AC will not work if the electric blower fan on the radiator does not come on. (It's under the shroud) ( Vehicle has engine fan and a electric fan hidden under the shroud..
Aug 01, 2010 | 2003 Dodge Durango
2005, Grand marquis, aircondition works on max or regular AC setting, but fan only works on the highest setting, will not work on slower fan speeds
this is a smiple repair, replace the blower motor resistor, this is what controls the lower speeds and is very common,the resistor is locate in the heater box next to the blower motor.
Jul 15, 2010 | 2005 Mercury Grand Marquis
Speed fun control airconditioned doesn´t work property.
Two possible areas I would check using an ohm meter. First is the blower resistor which is usually located by the blower motor and looks like a cement rectangle or a ceramic tube with wires attached to it. The resistor should have very low resistance but should not read open from the common lead to the other terminals. If it tests good test the continuity of the fan switch. Some cars have a fuse for the high and low blower speeds so you can check your fuse diagram and look for two blower or fan fuses. Good Luck.
Apr 02, 2010 | 2002 Chrysler Sebring
The airconditioning fan runs for a few seconds then quits. The rear operates fine.
Sounds like your blower motor has quit if it is inop on all levels. If high speed works and the other speeds do not, then its probally the rheastat or resistor pack
May 05, 2009 | GMC Envoy XL Cars & Trucks
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
