First take the speaker cover off the front by working it from the top of the cover on both sides with your fingers. It should snap out top first. Then unplug the cable that connects from the main board to the cover. After that take out the 2 screws from the bottom of the front silver cover. them you take off the silver housing on the front by pushing it towards the top from the bottom. do not pull out on it. It seemed easy if i applied the pressure using my thumbs while holding on to the black parts with my fingers.
Again. the silver front slides up about 1/2 inch and falls off. don't pull out on it.
After that take out the 4 screws that hold the screen into place.
The screen then needs to be pulled gently from its housing. Around the screen there is a metal house that holds it in. The metal houseing does nt come out. The screen needs to be gently worked out of it. I started with one corner and the rest came easily.
Pull it out slowly to make sure you don't put strain on any wires.
Hope that helps.
