Question about Dishwashers
Heller dishwasher error 004
I have a heller dishwasher has worked fine for 1 year now i turn it on tonight i get error 004 on screen and sounds like water going in and then pumps out again will not work ?
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Posted on Mar 11, 2010
I have just bought a Heller HWDSE12 dishwasher and need to replace the drainage pipe. Can you tell me where I could buy one? Thanks Tina
From here
HELLER HDW12 Parts List BigWarehouse Spares
or eBay
Haier Dishwasher Parts ' eBay
https://www.ebay.com.au > ... > Dishwasher Parts > Haier Dishwasher PartsResults 1 - 48 of 107 - Shop from the world's largest selection and best deals for Haier Dishwasher Parts. Shop with confidence on eBay! ... SUITS MODELS F&P DW60CEX1 PRODUCT CODE 80752-A HAIER MODELS HDW12-SFE3SS PRODUCT CODE 61584-A. AU $17.95. eBay Premium Service. Free postage.
Mar 18, 2018 | Dishwashers
Just moved into s property that has a heller DWH116 and it runs for 24 hours! Has this happened to you before? I read the manual and looked up online but I dont know what's wrong with it?
http://ernie.awa.com.au/Heller---Dishwasher/default.aspx u can find the manual here for it. in my opinion it sounds like a bad timer which can be changed but if it has quite a bit of age on it, then I would consider replacing the dishwasher itself.
May 21, 2016 | Hardware & Accessories
No sound from all sources. Some times...
Hello, I am sorry about your issue. Considering the age of the receiver [2005] it might be difficult to find parts for a repair. Please contact us at 800-229-1687 option #3 so that we can discuss possible options. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo Ht-R330 Stereo Receivers
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
Error Code: 004
shut off power to the unit first or unplug it after 1 min turn back on this may solve the problem
Aug 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Instruction Manual for HELLER automatic timer
hi can you tell what the cool or the hot pic are
Dec 07, 2008 | Hardware & Accessories
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Sep 21, 2008 | Dishwashers
Hi there,we are getting error code 004 coming up on our dishwasher, make is Heller, model is HDWE 12, as we don't have a manual,thanks
I have the HDWE12/SS manual, the following may help, or not!
According to my manual error 4 means it is "overfilled", and the possible cause is "too much inlet water". I doubt that is much help but that's all the manual says.
Error 2 is "longer draining time" with a possible cause of "the installation position of the drain pipe is too high"
Jun 09, 2008 | Dishwashers
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
Nov 12, 2006 | Danby DDW1805W Designer Series...
Dishwashers Logo
708 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
