Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
I have a Samsung Omnia and my battery life is down from 2 to 3 days between charges to 8 hours. Thought it was the battery and replaced it but still have the same problem. I have checked settings and can't seem to find anything that is out of the ordinary. When I first purchased the phone I could consistently go 24 to 48 hours without recharging and now I can't make it through a work day without it going dead.
    President:
  • Samsung Master
  • 782 Answers
It could be some application, that is draining the batt. Do a hard reset and see if any better.
Posted on Sep 20, 2009
Went to use it and it won't come on. Thought battery might be dead and plugged it in and it still won't come on.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Mar 11, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
Kobo not accepting a charge
Jul 28, 2014 | Kobo Arc
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
Jun 07, 2014 | Tablets & eReaders
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
used up.
Jun 05, 2014 | Tablets & eReaders
New Samsung Galaxy Note 10.0 battery life and charging time
Sounds normal to me!!
The further away from wifi router you are the more power is needed by the wifi card.... etc etc so the 8 hours is in perfect conditions with the screen brightness at minimum and no apps running!! It's safe to say that, whatever battery life is quoted for any device you should only expect to acheive half that in the real world.
The screen is prob responsible for 80% of the battery's power drain. Turn the brightness down. Stay in same room as router. close down un-used apps that demand cpu and network (wifi card) time.
Shut it down completely when charging don't just let slip into standby. Also don't charge it on a cold or hot place such as a window sil. To high or low tempretures will increase charge time and will damage the battery lowering it's capacity.
May 30, 2013 | Samsung Galaxy Note 10.1
My office has 2 Tekk NT 90 radios, but no user's manual or instructions for them. Need basic operation info so they can be used.
The Tekk NT90 is a basic walkie-talkie style radio. With a good battery they will operate a full business day on a charge. The radios should be charged overnight (or 8-12 hours) after the battery is depleted or nearly depleted. If using these in a business situation you can usually go a full 8-hr day on a charge. Battery packs have approx a 2 year life expectancy before needing replaced.
If you need more info, contact Tekk Inc at 800-521-8355.
Best regards.
Oct 18, 2010 | TEKK Radio Communications
Omnia 2 charging problem
I have the same problem with mine, It charges fine when its turned off and plugged into the wall charger but dussnt recognize the charger when its on. kinda retarded. Could be a manufacturing fault thats coming up now =(.
Planning on sending it in coz its still covered under its warrenty. I suggest you do the same if yours is, otherwise u might just have to charge it from the usb port from now on... kinda dissapointing from samsung, thought they wouldve defntly got everything together after the original omnia failed so much
Jun 26, 2010 | Samsung Omnia Cell Phone
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
How much time to we have to charge Samsung Omnia phone
Depends on your firmware. Updating your firmware on the somsaung site will prolong your battery life. Mine used to last about 2hours with heavy repative use. Music, gps, video etc. Standby would last about a day and a half with a few calls. Now it lasts about 4-5hours with heavy use and standby up to about 4 days with calls here and there.
Mar 26, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Battery life is rubbish
The first time you charge a battery, you must charge it for at least 16 hours, otherwise the battery builds up a memory, and it will not charge further than that. Try buying a new battery and charging it for at least 16 hours, if this was not done the first time. If this was done, or you are using a new battery, it might be that the battery connector is faulty and needs to be replaced
Aug 02, 2007 | Samsung YH-925GS MP3 Player
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
155 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
