Question about Peavey Music
Kb100 peavey amp guide settings fot this instrument
Can anyone give me a basic guide settings for this amp
    Problem Solver:
  • 8 Answers
Try this:
http://www.peavey.com/assets/literature/manuals/80300976.pdf
If that link does not work,here is a general link to that area where you can download the PDF docs for manuals.
http://www.peavey.com/support/searchmanuals/archived.cfm?page=K
Posted on Sep 22, 2009
What is causing humming sound in headphones?
Well, there are a couple things in the troubleshooting process you may want to check first. If Possible,
1. Have you tried a different pair of headphones thru the same jack?, Is it buzzing as well? Then its not the headphones. If the buzzing stops with a different pair, then we proceed to to headphones in question.
so , headphones are buzzing. Both sides? if yes , or even 1-side, then yes, it is a ground issue. can you expose the wiring at the input jack?
Basically, you want to put an ohm meter on each wire and independently check each wire for continuity. check for any breaks in the line, and or check to see if a wire is crossing over to ground via a break. so check each line to itself, then each line to each other.
if you fo not understand on the process of using an ohm meter? you can go to this You Tube link and it will give you a general understanding.
hopefully this gives you a little insight? If not?, ask the question again, and also include the make & model of the headphone set. that always helps;m Thanks,
Good luck.!!
Mar 22, 2016 | Music
How do I set up my Peavey Vypyr 30 amp and my Sanpera 1 footswitch to sound right?
your best bet is to contact Peavey directly. they can provide you with the manual and discuss your application. Here is teir contact page-
Peavey com
Mar 01, 2015 | Peavey Music
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
I'm using an oxygen 49 midi controller with ableton and it seems to work fine for a while and suddenly if I begin to mess with other parts of ableton, let's say another midi track the controller...
There are several reasons why this could be happening, assuming it's Windows, not MAC.
-Check to make sure the OUT port isn't set. You only need IN for basic controller use.
- Make sure the channel your using is armed (button below Solo & Mute should be red) [this is the most likely problem]
Another problem is the USB power settings in Windows. The default is set to allow the Computer to monitor and turn off USB ports automatically to save power. But it doesn't turn them back on automatically. You'll want change these settings regardless to help reduce latency issues.
-Go to Device Manager> USB Controllers> double click & change power settings to OFF for all Root Hubs.
Here is a guide to help optimize Windows to lessen Latency, Dropouts and Clicks /Pops. It's for Studio One, but the settings are the same for Windows.
You might want to give Studio One a try. I've used everything and by far Studio One is the easiest with the least issues. The free version is better than most DAWS paid versions. It can definitely help eliminate a lot of the everyday headaches that come with using Abelton, Cubase, Protools and even FruityLoops (which is pretty gay anyway).
M-Audio is also notorious for USB hardware related issues. A lot of times I find it turns out to be a bad connection between the plug and keyboard port, which tends to wear after awhile. It can go unnoticed because it still fits tight enough to get power, but not enough to keep the board fully functional.
Hope this helps.
Jul 13, 2017 | M-Audio Music
I HAVE A ZOOM MRS-802 B. IT will not start up. keeps reading HDD eror. Can not scan disc due to this reading pops up after step 1 of BASIC MAintenance Procedure. Does not go to ExtFunc pops back to...
Mine did the same thing. Just by chance we had a universal laptop power supply unit with interchangeable tips made by powertran & my wife said to give it a try. The unit has a display window on it & it reads 16.9 volts when the zoom is running. When I plugged it in I couldn't believe it was going through it's start up menu. On the package it says 15 - 20 volts DC 90 watts & I reckoned it shocked the zoom into working again...well anyway, it worked & the zoom is running again. The power box package cost $89AU that I got at an electronics store.
Jan 30, 2011 | Zoom Music
When I'm playing on my amp there is a strange noice coming out of my amp. At first I thought it was my guitar, but it is really my amp... does anyone know how to solve?
"A strange noise" does NOT give us much to go on...
Please note that relatively low volume digitizing noise often exists from teh digital effects processors... it should be well below the normal playing volume.
Aug 09, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
When I play my Line 6 Spider III Amp (Stack), the volume and gain output is very weak even though the settings are maxed, and the tone is very strained and sharp. It basically lost all of it's kick.
Poor contacts at jacks can cause this... it results in the contacts acting like a small capacitor passing only the high frequencies at very low level.
Power amp inout jacks are notorious with switch contacts that pass the preamp signal to the power amp if the power amp input isn't used.
There are many other possibilities and only hands on troubleshooting will determine the cause.
Jul 23, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
How To Turn Drum Beat Off
From what I remember from my recent tinkering you press the guide select button. Then either use the patch/value know and parameter buttons, OR it may be the guide level knob to switch the volume down until it is off. I believe I then saved the patch to preserve the setting and keep that irritating guide at bay! It really should be more intuitive, ideally knod turned to zero = OFF. But no. Ah well, hope you get it sorted. I have a problem too, maybe you have same one? It may be the unit itself. Search - Beggining of loop missing on FIRST playback - if you get a chance. Let me know if yours does it too?
Mar 06, 2009 | Boss Rc 50
Fender M-80 electric Guitar Amp.
You might have a ground problem. Does it do it in different outlets or when you take it to someone else's house? One easy solution to ground problems can be running a three prong to two prong adapter on the power cable. Give that a try and see if it helps.
Nov 09, 2008 | Fender Fm25dsp 1x10' Guitar Combo...
Music Logo
248 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Peavey Music Expert? Answer questions, earn points and help others
