Question about Citizen Blue Angels Skyhawk Watch
Hi, The second hand and the digital seconds aren't the same...do I have to "reset" the watch. I tried pushing A and B at the same time.
  • 183 Answers
When in the time set mode pressing the bottom button when the seconds field is flashing will return the seconds to "00" You should be able to correct the seconds this way. If this is not working then reset the watch and start the set process again.
Here are instructions for setting this watch.
http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
Posted on Sep 20, 2009
  • 8,404 Answers
Hi there ...
Here is what I suggest. Start here: http://www.citizenwatch.com/ select your area, select technical assistance. If you dont find exactly what you need there, contact them and you will receive the very finest customer service available.
I have this watch and there is no way to adjust the hands directly. The hands are driven as a result of the digital readings. IF they are out of whack, you need genuine Citizen service.
I hope you find value in this response.
Thanks for posting at FixYa.com
Please vote
thanks
Posted on Nov 13, 2009
How do I reset the millisecond hand used in the stop watch function on my nixon Ride SS watch?
Try this:
Resetting Chronograph Hands:
Note: Some Nixon watches come equipped with a "screw-down" crown; the crown must be unscrewed by turning it counterclockwise before it can be pulled out)
1. Pull the crown all the way out to position 2.
2. Push the crown in slightly to position 1.
3. Push top pusher button to advance the second hand to line up with the 12:00 position
4. Push the crown back in. (Make sure it is screwed in if it is a screw crown)
Jan 02, 2014 | Watches
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Mar 23, 2009 | Watches
Need to know how to operate Cartier Tank Francaise Chronography W
The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
Do as follows:
1) push the top button once- seconds hand starts moving,
2) push the top button once more- seconds hand stops,
3) push the bottom button once- seconds hand returns to zero.
You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
Do not forget to rate, please.
Jan 10, 2009 | Cartier Tank Americaine W2601156 Wrist...
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Tag Heuer Aquaracer reset red hand
THANK YOU THANK YOU THANK YOU!!! I had a similar issue and this saved me!!!!
Apr 14, 2008 | Tag Heuer Aquaracer Quartz Chronograph...
Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
Mar 22, 2008 | Watches
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Citizen Blue Angels Skyhawk Watch Logo
189 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
